[postgis-tickets] [PostGIS] #5209: Upgrade issue with topology
PostGIS trac at osgeo.org
Thu Aug 11 09:24:59 PDT 2022
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  blocker   |  Milestone:  PostGIS 3.2.3
Component:  topology  |    Version:  3.2.x
 Keywords:            |
 From https://lists.osgeo.org/pipermail/postgis-
 users/2022-August/045600.html
 When building packages today for the new postgres releases I ran into the
 below
 error for the PostGIS package when running tests:
   ALTER EXTENSION
   ERROR:  function layertrigger() is not a member of extension
 "postgis_topology"
   DETAIL:  An extension is not allowed to replace an object that it does
 not own.
 It seems that it's related to the CVE which was fixed in the new postgres
 releases today.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5209>
