[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc1-3-g755e8114e
Fri Aug 12 07:54:50 PDT 2022
the project "PostGIS".
       via  755e8114efee5e5e9999dcaa99c48a812beb708a (commit)
      from  0fac2660f2fe5b3e3510f2dd3a82741c1b9c309f (commit)
revisions in full, below.
commit 755e8114efee5e5e9999dcaa99c48a812beb708a
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 16:51:09 2022 +0200
    run_test.pl: run psql in quiet mode when loading scripts
diff --git a/regress/run_test.pl b/regress/run_test.pl
index efafb29ae..c66331f5b 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1383,7 +1383,7 @@ sub load_sql_file
 	if ( -e $file )
 		# ON_ERROR_STOP is used by psql to return non-0 on an error
-		my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
+		my $psql_opts = "--quiet --no-psqlrc --variable ON_ERROR_STOP=true";
 		my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
 		$cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
 		$cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
Summary of changes:
 regress/run_test.pl | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
