[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.6-12-ga2e77fcad
git at osgeo.org
git at osgeo.org
Fri Aug 12 07:55:28 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
via a2e77fcadd8da984dcf0b2776ef98453ab079f52 (commit)
from 15d949f368e92ee882cab8086643efcd003d0582 (commit)
revisions in full, below.
commit a2e77fcadd8da984dcf0b2776ef98453ab079f52
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Aug 12 16:51:09 2022 +0200
run_test.pl: run psql in quiet mode when loading scripts
diff --git a/regress/run_test.pl b/regress/run_test.pl
index efafb29ae..c66331f5b 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1383,7 +1383,7 @@ sub load_sql_file
if ( -e $file )
# ON_ERROR_STOP is used by psql to return non-0 on an error
- my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
+ my $psql_opts = "--quiet --no-psqlrc --variable ON_ERROR_STOP=true";
my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
$cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
$cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
Summary of changes:
regress/run_test.pl | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
