[postgis-tickets] [PostGIS] #5187: Upgrade failures on 2.5 to 3.3.0
PostGIS trac at osgeo.org
Fri Aug 12 09:40:01 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  critical               |  Milestone:  PostGIS 2.5.8
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
 * milestone:  PostGIS 3.3.0 => PostGIS 2.5.8
Comment:
 Reopening as now we backported the upgrade support after CVE-2022-2625
 PostgreSQL fix (see #5209 and #5210) the problem also exists in older
 branches. Up to 2.5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5187#comment:6>
