[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.2-19-g268080c4d
Fri Aug 12 10:30:44 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  268080c4d5be2be0d3e969b16d6d678ff69a0a1a (commit)
      from  50932f348030d25d0801dfe3529ef7dbaf8ff62a (commit)
revisions in full, below.
commit 268080c4d5be2be0d3e969b16d6d678ff69a0a1a
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 19:29:00 2022 +0200
    run_test.pl: fix support for pre-split-raster unpackaged upgrade testing
diff --git a/regress/run_test.pl b/regress/run_test.pl
index c66331f5b..192286b2f 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -125,7 +125,8 @@ sub has_split_raster_ext
   my $fullver = shift;
   # unpackaged is always current, so does have
   # split raster already.
-  return 1 if $fullver =~ /^unpackaged/;
+  return 1 if $fullver =~ /^unpackaged$/;
+  $fullver =~ s/unpackaged//;
   my @ver = split(/\./, $fullver);
   return 0 if ( $ver[0] < 3 );
   return 1;
@@ -1716,7 +1717,7 @@ sub upgrade_spatial_extensions
       return 1;
-    if ( $OPT_WITH_RASTER )
+    if ( $OPT_WITH_RASTER && has_split_raster_ext($OPT_UPGRADE_FROM) )
         my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
Summary of changes:
 regress/run_test.pl | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
