[postgis-tickets] [PostGIS] #5212: Can't regress test PostGIS against sandboxed systems
PostGIS trac at osgeo.org
Fri Aug 12 11:23:18 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.2.3
Component:  build/upgrade/install  |    Version:  3.2.x
 Keywords:                         |
 I was using pgtwlist to try to simulate a sandboxed user such as one would
 find in a classroom or in a cloud setup.
 Basic steps in my setup, I install the
 https://github.com/dimitri/pgextwlist.git extension, restart the
 postgresql service
 ALTER SYSTEM SET
 extwlist.extensions='postgis,postgis_topology,postgis_sfcgal,
 address_standardizer,postgis_tiger_geocoder';
 SELECT pg_reload_conf();
 The user I created, has rights to create databases but is not a super
 user, and I confirmed I can do CREATE EXTENSION postgis with this user.
 When I try to regress though, I get an error
 > "/var/run/postgresql/.s.PGSQL.5433" failed: FATAL:  permission denied
 > to set parameter "lc_messages"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5212>
