[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.2-20-g632618a14
Fri Aug 12 11:50:16 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  632618a14db381ca5b08a0ca0819ee42233fda3d (commit)
      from  268080c4d5be2be0d3e969b16d6d678ff69a0a1a (commit)
revisions in full, below.
commit 632618a14db381ca5b08a0ca0819ee42233fda3d
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 20:49:20 2022 +0200
    run_test.pl: raster extension needs be upgraded only when split from core
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 192286b2f..8e1016e53 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1717,7 +1717,7 @@ sub upgrade_spatial_extensions
       return 1;
-    if ( $OPT_WITH_RASTER && has_split_raster_ext($OPT_UPGRADE_FROM) )
+    if ( $OPT_WITH_RASTER && has_split_raster_ext(${nextver}) )
         my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
Summary of changes:
 regress/run_test.pl | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
