[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.6-17-g6ec1e6caf
Fri Aug 12 12:03:40 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  6ec1e6cafcd53df5890fef65dc776ccd02313181 (commit)
      from  72f4159832dd9a6ac86fd3cb9f2f1c40b020fc3d (commit)
revisions in full, below.
commit 6ec1e6cafcd53df5890fef65dc776ccd02313181
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue May 4 18:13:22 2021 +0200
    Move hard-coded upgrade data from run_test.pl to hook scripts
diff --git a/GNUmakefile.in b/GNUmakefile.in
index a59fbabcb..bf2f9dd49 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -197,11 +197,9 @@ ifeq ($(HAVE_SFCGAL),yes)
 	include sfcgal/regress/tests.mk
 endif
 ifeq (@TOPOLOGY@,topology)
-	override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
 	include topology/test/tests.mk
 endif
 ifeq (@RASTER@,raster)
-	override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
 	include raster/test/regress/tests.mk
 endif
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
index 5c0ea4854..91173802e 100644
--- a/raster/test/regress/Makefile.in
+++ b/raster/test/regress/Makefile.in
@@ -180,9 +180,8 @@ rtpostgis.sql: ../../rt_pg/rtpostgis.sql
 	$(PERL) -lpe "s'\\\$$libdir'$(REGRESS_INSTALLDIR)/lib'g" $< > $@
-override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
 topsrcdir = $(realpath ../../../)
+srcdir = $(realpath .)
 include tests.mk
 include ../../../regress/runtest.mk
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
new file mode 100644
index 000000000..49f51173b
--- /dev/null
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -0,0 +1 @@
+DROP TABLE upgrade_test_raster;
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 000000000..8c000dbaf
--- /dev/null
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -0,0 +1,16 @@
+CREATE TABLE upgrade_test_raster(r raster);
+INSERT INTO upgrade_test_raster(r) VALUES
+	ST_AddBand(
+		ST_MakeEmptyRaster(
+			10, 10, 1, 1, 2, 2, 0, 0,4326
+		1,
+		'8BSI'::text,
+		-129,
+		NULL
+--SET client_min_messages TO ERROR;
+SELECT AddRasterConstraints('upgrade_test_raster', 'r');
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 39fb5297d..755acbb53 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -10,6 +10,12 @@
+override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
+RUNTESTFLAGS_INTERNAL += \
+  --before-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-before-upgrade-raster.sql \
+  --after-upgrade-script  $(topsrcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
 RASTER_TEST_FIRST = \
 	check_gdal \
 	load_outdb
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 1b32ec3d7..acdfeccde 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -20,6 +20,10 @@ INTERRUPTTESTS=@INTERRUPTTESTS@
 current_dir := $(dir $(abspath $(lastword $(MAKEFILE_LIST))))
+  --before-upgrade-script $(topsrcdir)/regress/hooks/hook-before-upgrade.sql \
+  --after-upgrade-script  $(topsrcdir)/regress/hooks/hook-after-upgrade.sql
 TESTS += \
 	$(topsrcdir)/regress/core/affine \
 	$(topsrcdir)/regress/core/bestsrid \
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 000000000..459f80249
--- /dev/null
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -0,0 +1,2 @@
+DROP VIEW IF EXISTS upgrade_view_test;
+DROP TABLE upgrade_test;
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 000000000..d4bcb8cd6
--- /dev/null
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -0,0 +1,26 @@
+CREATE TABLE upgrade_test(g1 geometry, g2 geography);
+INSERT INTO upgrade_test(g1,g2) VALUES
+('POINT(0 0)', 'LINESTRING(0 0, 1 1)'),
+('POINT(1 0)', 'LINESTRING(0 1, 1 1)');
+-- We know upgrading with an st_union() based view
+-- fails unless you're on PostgreSQL 12, so we don't
+-- even try that.
+-- We could re-enable this test IF we fix the upgrade
+-- in pre-12 versions. Refer to
+-- https://trac.osgeo.org/postgis/ticket/4386
+DO $BODY$
+DECLARE
+	vernum INT;
+BEGIN
+	show server_version_num INTO vernum;
+	IF vernum >= 120000
+	THEN
+		RAISE DEBUG '12+ server (%)', vernum;
+    CREATE VIEW upgrade_view_test AS
+    SELECT ST_Union(g1) FROM upgrade_test;
+	END IF;
+END;
+$BODY$ LANGUAGE 'plpgsql';
diff --git a/regress/runtest.mk b/regress/runtest.mk
index cd4cf261c..5df1a3968 100644
--- a/regress/runtest.mk
+++ b/regress/runtest.mk
@@ -4,17 +4,22 @@ abssrcdir := $(realpath .)
 TESTS := $(patsubst $(topsrcdir)/%,$(abstopsrcdir)/%,$(TESTS))
 TESTS := $(patsubst $(abssrcdir)/%,./%,$(TESTS))
 check-regress:
-	@$(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(TESTS)
+	@echo "RUNTESTFLAGS: $(RUNTESTFLAGS)"
+	@echo "RUNTESTFLAGS_INTERNAL: $(RUNTESTFLAGS_INTERNAL)"
+	@$(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(RUNTESTFLAGS_INTERNAL) $(TESTS)
 	# Will now run upgrade test if RUNTESTFLAGS was not already doing that
 	@if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
-		$(PERL) $(topsrcdir)/regress/run_test.pl --upgrade $(RUNTESTFLAGS) $(TESTS); \
+		$(PERL) $(topsrcdir)/regress/run_test.pl \
+      --upgrade \
+      $(RUNTESTFLAGS) \
+      $(TESTS); \
 	fi
 check-long:
diff --git a/topology/test/Makefile.in b/topology/test/Makefile.in
index cef910834..865151479 100644
--- a/topology/test/Makefile.in
+++ b/topology/test/Makefile.in
@@ -40,9 +40,8 @@ check-regress: check-regress-deps
 check-regress-deps: topo_predicates.sql load_topology.sql load_topology-4326.sql
-override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
 topsrcdir = $(realpath ../../)
 include tests.mk
 include ../../regress/runtest.mk
diff --git a/topology/test/regress/hooks/hook-after-upgrade-topology.sql b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
index 000000000..c7e2e9ce8
--- /dev/null
+++ b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
@@ -0,0 +1,2 @@
+SELECT topology.DropTopology('upgrade_test');
diff --git a/topology/test/regress/hooks/hook-before-upgrade-topology.sql b/topology/test/regress/hooks/hook-before-upgrade-topology.sql
index 000000000..9c5529f7e
--- /dev/null
+++ b/topology/test/regress/hooks/hook-before-upgrade-topology.sql
@@ -0,0 +1,2 @@
+SELECT topology.createTopology('upgrade_test');
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index eb8b4b598..c66c313f7 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -10,6 +10,12 @@
+override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
+  --before-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-before-upgrade-topology.sql \
+  --after-upgrade-script  $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
 TESTS += \
   $(topsrcdir)/topology/test/regress/addedge.sql \
 	$(topsrcdir)/topology/test/regress/addface2.5d.sql \
Summary of changes:
 GNUmakefile.in                                     |  2 --
 raster/test/regress/Makefile.in                    |  3 +--
 .../regress/hooks/hook-after-upgrade-raster.sql    |  1 +
 .../regress/hooks/hook-before-upgrade-raster.sql   | 16 +++++++++++++
 raster/test/regress/tests.mk                       |  6 +++++
 regress/core/tests.mk.in                           |  4 ++++
 regress/hooks/hook-after-upgrade.sql               |  2 ++
 regress/hooks/hook-before-upgrade.sql              | 26 ++++++++++++++++++++++
 regress/runtest.mk                                 | 11 ++++++---
 topology/test/Makefile.in                          |  3 +--
 .../regress/hooks/hook-after-upgrade-topology.sql  |  2 ++
 .../regress/hooks/hook-before-upgrade-topology.sql |  2 ++
 topology/test/tests.mk                             |  6 +++++
 13 files changed, 75 insertions(+), 9 deletions(-)
 create mode 100644 raster/test/regress/hooks/hook-after-upgrade-raster.sql
 create mode 100644 raster/test/regress/hooks/hook-before-upgrade-raster.sql
 create mode 100644 regress/hooks/hook-after-upgrade.sql
 create mode 100644 regress/hooks/hook-before-upgrade.sql
 create mode 100644 topology/test/regress/hooks/hook-after-upgrade-topology.sql
 create mode 100644 topology/test/regress/hooks/hook-before-upgrade-topology.sql
hooks/post-receive
