[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.6-20-ge416996d5
Fri Aug 12 12:45:00 PDT 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  e416996d5f415859fab4483b5e2391d4d4371f60 (commit)
      from  4b3aa4d7655f0911a0125449ad1f0eda28892289 (commit)
revisions in full, below.
commit e416996d5f415859fab4483b5e2391d4d4371f60
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 21:40:51 2022 +0200
    run_test: don't try to handle raster split when coming from unpackaged
    References #5213 in stable-3.0 branch (3.0.7dev)
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 8e1016e53..87fb1e50f 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1664,41 +1664,28 @@ sub upgrade_spatial_extensions
       die;
-    # Handle raster split if coming from pre-split and going
-    # to splitted raster
-    if ( $OPT_UPGRADE_FROM && has_split_raster_ext($OPT_UPGRADE_TO) &&
+    # Handle raster split if coming from pre-split extension
+    # and going to splitted raster
+    if ( $OPT_UPGRADE_FROM &&
+         ! $OPT_UPGRADE_FROM =~ /^unpackaged/ &&
+         has_split_raster_ext($OPT_UPGRADE_TO) &&
          ! has_split_raster_ext($OPT_UPGRADE_FROM) )
-      if ( $OPT_WITH_RASTER )
-        # upgrade of postgis must have unpackaged raster, so
-        # we create it again here
-				my $sql = package_extension_sql('postgis_raster', ${nextver});
+      # upgrade of postgis must have unpackaged raster, so
+      # we create it again here
+      my $sql = package_extension_sql('postgis_raster', ${nextver});
-        print "Upgrading PostGIS Raster in '${DB}' using: ${sql}\n" ;
+      print "Packaging PostGIS Raster in '${DB}' using: ${sql}\n" ;
-        my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
-        my $rv = system($cmd);
-        if ( $rv ) {
-          fail "Error encountered creating EXTENSION POSTGIS_RASTER from unpackaged on upgrade", $REGRESS_LOG;
-          die;
+      my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+      my $rv = system($cmd);
+      if ( $rv ) {
+        fail "Error encountered creating EXTENSION POSTGIS_RASTER from unpackaged on upgrade", $REGRESS_LOG;
+        die;
-      else
-        # Raster support was not requested, so drop it if
-        # left unpackaged
-        print "Packaging PostGIS Raster in '${DB}' for later drop using: ${sql}\n" ;
-				$sql = package_extension_sql('postgis_raster', ${nextver});
-        $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
-        $rv = system($cmd);
-        if ( $rv ) {
-          die;
+      if ( ! $OPT_WITH_RASTER )
         print "Dropping PostGIS Raster in '${DB}' using: ${sql}\n" ;
         $sql = "DROP EXTENSION postgis_raster";
Summary of changes:
 regress/run_test.pl | 45 ++++++++++++++++-----------------------------
 1 file changed, 16 insertions(+), 29 deletions(-)
hooks/post-receive
