[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.6-20-g7fc7c0d6d
Fri Aug 12 12:47:31 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  7fc7c0d6db134bb1c14a64093ffa6dfc7c06a17c (commit)
      from  23f1459010c4271fe74a18720116ffd9c0a4617e (commit)
revisions in full, below.
commit 7fc7c0d6db134bb1c14a64093ffa6dfc7c06a17c
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 12 20:49:20 2022 +0200
    run_test.pl: raster extension needs be upgraded only when split from core
diff --git a/regress/run_test.pl b/regress/run_test.pl
index fcd350741..87fb1e50f 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1704,7 +1704,7 @@ sub upgrade_spatial_extensions
       return 1;
-    if ( $OPT_WITH_RASTER && has_split_raster_ext($OPT_UPGRADE_FROM) )
+    if ( $OPT_WITH_RASTER && has_split_raster_ext(${nextver}) )
         my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
Summary of changes:
 regress/run_test.pl | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
