[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.6-21-gcb54e728c
Fri Aug 12 22:41:47 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  cb54e728c0758d2c1fda2644ba22dd9110fccd26 (commit)
      from  7fc7c0d6db134bb1c14a64093ffa6dfc7c06a17c (commit)
revisions in full, below.
commit cb54e728c0758d2c1fda2644ba22dd9110fccd26
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Aug 13 01:12:52 2022 +0200
    Fix perl syntax logic
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 87fb1e50f..ff1faaa14 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1667,9 +1667,9 @@ sub upgrade_spatial_extensions
     # Handle raster split if coming from pre-split extension
     # and going to splitted raster
     if ( $OPT_UPGRADE_FROM &&
-         ! $OPT_UPGRADE_FROM =~ /^unpackaged/ &&
+         ( not $OPT_UPGRADE_FROM =~ /^unpackaged/ ) &&
          has_split_raster_ext($OPT_UPGRADE_TO) &&
-         ! has_split_raster_ext($OPT_UPGRADE_FROM) )
+         not has_split_raster_ext($OPT_UPGRADE_FROM) )
       # upgrade of postgis must have unpackaged raster, so
       # we create it again here
Summary of changes:
 regress/run_test.pl | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
