[postgis-tickets] [PostGIS] #5215: gitlab-ci is not checking installs in 2.5 branch
PostGIS trac at osgeo.org
Sat Aug 13 00:00:23 PDT 2022
  Reporter:  strk       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 2.5.8
 Component:  buildbots  |    Version:  2.5.x
Resolution:  fixed      |   Keywords:
Comment (by strk):
 For the record: the master branch at time of writing (3.3.0rc1) correctly
 handles a the `make installcheck RUNTESTFLASG=-v` so at some point the
 code was fixed to not completely override internal flags.
 I believe it happened with [155a4e664b51ed6742ca8adffbdc60f1059a9c30/git]
 which introduced the use of RUNTESTFLAGS_INTERNAL which didn't make it
 into 3.0 and 2.5 branches (but 3.0 already used in gitlab-ci config the
 working call)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5215#comment:3>
