[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc1-9-g5e87b7215
Sat Aug 13 00:27:24 PDT 2022
the project "PostGIS".
       via  5e87b721530008fce0e498666732da962184b246 (commit)
      from  d5b74033e2353fd5edf901f4fc5029a393429ef6 (commit)
revisions in full, below.
commit 5e87b721530008fce0e498666732da962184b246
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Aug 13 08:14:35 2022 +0200
    run_test: stop assuming default version has split raster
    Fixes --extension --upgrade tests where --upgrade-path
    is NOT given and the default version in .control file
    is older than 3.0 (pre-split times)
diff --git a/regress/run_test.pl b/regress/run_test.pl
index ff1faaa14..4d852bdd6 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1470,12 +1470,7 @@ sub prepare_spatial_extensions
-	if ( $OPT_WITH_RASTER && (
-		# NOTE: this code is assuming that the default version
-		# (!$OPT_UPGRADE_FROM) has split raster extension
-		! $OPT_UPGRADE_FROM ||
-		has_split_raster_ext($OPT_UPGRADE_FROM)
+	if ( $OPT_WITH_RASTER && has_split_raster_ext($OPT_UPGRADE_FROM) )
 		my $sql = "CREATE EXTENSION postgis_raster";
 		if ( $OPT_UPGRADE_FROM ) {
Summary of changes:
 regress/run_test.pl | 7 +------
 1 file changed, 1 insertion(+), 6 deletions(-)
hooks/post-receive
