[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc1-11-g0a627466b
Sat Aug 13 01:26:52 PDT 2022
the project "PostGIS".
       via  0a627466b1d414949488e22dcfe69b569cc533a7 (commit)
      from  556f868249c835984560630e598123fb4dea58a4 (commit)
revisions in full, below.
commit 0a627466b1d414949488e22dcfe69b569cc533a7
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Aug 13 10:26:41 2022 +0200
    Add --build-dir switch to run_test.pl
diff --git a/regress/run_test.pl b/regress/run_test.pl
index aea1799f7..0d3dfee79 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -51,9 +51,6 @@ BEGIN {
 our $DB = $ENV{"POSTGIS_REGRESS_DB"} || "postgis_reg";
 our $REGDIR = abs_path(dirname($0));
 our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"} || ${REGDIR} . '/..';
-our $SHP2PGSQL = $TOP_BUILDDIR . "/loader/shp2pgsql";
-our $PGSQL2SHP = $TOP_BUILDDIR . "/loader/pgsql2shp";
-our $RASTER2PGSQL = $TOP_BUILDDIR . "/raster/loader/raster2pgsql";
 our $sysdiff = !system("diff --strip-trailing-cr $0 $0 2> /dev/null");
@@ -97,6 +94,7 @@ GetOptions (
 	'expect' => \$OPT_EXPECT,
 	'extensions' => \$OPT_EXTENSIONS,
 	'schema=s' => \$OPT_SCHEMA,
+	'build-dir=s' => \$TOP_BUILDDIR,
 	'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
 	'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
 	'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
@@ -108,6 +106,10 @@ if ( @ARGV < 1 )
 	usage();
+our $SHP2PGSQL = $TOP_BUILDDIR . "/loader/shp2pgsql";
+our $PGSQL2SHP = $TOP_BUILDDIR . "/loader/pgsql2shp";
+our $RASTER2PGSQL = $TOP_BUILDDIR . "/raster/loader/raster2pgsql";
 if ( $OPT_UPGRADE_PATH )
   $OPT_UPGRADE = 1; # implied
@@ -177,7 +179,8 @@ foreach my $exec ( ($SHP2PGSQL, $PGSQL2SHP) )
 		print "failed\n";
 		print STDERR "Unable to find $exec executable.\n";
-		die "HINT: set POSTGIS_TOP_BUILD_DIR env variable to the build dir.\n";
+		print STDERR "TOP_BUILDDIR is ${TOP_BUILDDIR}\n";
+		die "HINT: use POSTGIS_TOP_BUILD_DIR env or --build-dir switch the specify top build dir.\n";
@@ -592,6 +595,9 @@ Options:
   --clean         cleanup test logs on exit
   --expect        save obtained output as expected
   --extension     load using extensions
+  --build-dir <path>
+                  specify where to find the top build dir of PostGIS,
+                  to find binaries and scripts
   --after-create-script <path>
                   script to load after spatial db creation
                   (multiple switches supported, to be run in given order)
Summary of changes:
 regress/run_test.pl | 14 ++++++++++----
 1 file changed, 10 insertions(+), 4 deletions(-)
hooks/post-receive
