[postgis-tickets] [PostGIS] #5216: Error: Package: gdal-libs-1.11.4-12.rhel7.x86_64 (@pgdg11)
PostGIS trac at osgeo.org
Sat Aug 13 14:12:52 PDT 2022
 Reporter:  marc3932   |      Owner:  pramsey
     Type:  patch      |     Status:  new
 Priority:  high       |  Milestone:  PostGIS GDAL
Component:  postgis    |    Version:  3.1.x
 Keywords:  gdal-libs  |
 $ cat /etc/redhat-release
 Red Hat Enterprise Linux Server release 7.9 (Maipo)
 # rpm -qa | grep armadillo* | sort
 armadillo-8.600.1-2.el7.x86_64
 # rpm -qa | grep gdal-libs* | sort
 Problem:
 # yum update
            Requires: libarmadillo.so.8()(64bit)
            Removing: armadillo-8.600.1-2.el7.x86_64 (@EPEL7_x64_localrepo)
            Updated By: armadillo-10.8.2-1.el7.x86_64 (epel)
               ~libarmadillo.so.10()(64bit)
 - It appears the newer armadillo packages update the libarmadillo.so.8
 library to libarmadillo.so.10
 - So it looks like gdal-libs will need to be rebuilt against newer
 armadillo to fix the problem.
 # subscription-manager repos --list-enabled
     Available Repositories in /etc/yum.repos.d/redhat.repo
 Repo ID:   rhel-7-server-rpms
 Repo Name: Red Hat Enterprise Linux 7 Server (RPMs)
 Repo URL:  https://red-inf-
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel/server/7/$releasever/$basearch/os
 Enabled:   1
 Repo ID:   rhel-server-rhscl-7-rpms
 Repo Name: Red Hat Software Collections RPMs for Red Hat Enterprise Linux
 7 Server
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel/server/7/$releasever/$basearch/rhscl/1/os
 Enabled:   1
 Repo ID:   rhel-7-server-extras-rpms
 Repo Name: Red Hat Enterprise Linux 7 Server - Extras (RPMs)
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel/server/7/7Server/$basearch/extras/os
 Enabled:   1
 Repo ID:   ESRI_EPEL_7_x86_64
 Repo Name: x86_64
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/custom/EPEL_7/x86_64
 Enabled:   1
 Repo ID:   rhel-7-server-optional-rpms
 Repo Name: Red Hat Enterprise Linux 7 Server - Optional (RPMs)
 cap-p01.esri.com/pulp/repos/ESRI/LEP_Patch/cv_patch/content/dist/rhel/server/7/$releasever/$basearch/optional/os
 Enabled:   1
 --Workaround:
 # yum update --exclude=gdal-libs* --exclude=armadillo*
 #Aug/10/2022
 #yum update --exclude=postgis31_11 --exclude=postgis31_12
 --exclude=postgis31_13 --exclude=postgis32_13 --exclude=postgresql11*
 --exclude=postgresql12* --exclude=postgresql13* --exclude=gdal-libs*
 $ rpm -qa | grep postgres* | sort
 postgresql11-11.16-1PGDG.rhel7.x86_64
 postgresql11-contrib-11.16-1PGDG.rhel7.x86_64
 postgresql11-libs-11.16-1PGDG.rhel7.x86_64
 postgresql11-server-11.16-1PGDG.rhel7.x86_64
 postgresql12-12.11-1PGDG.rhel7.x86_64
 postgresql12-contrib-12.11-1PGDG.rhel7.x86_64
 postgresql12-libs-12.11-1PGDG.rhel7.x86_64
 postgresql12-server-12.11-1PGDG.rhel7.x86_64
 postgresql13-13.7-1PGDG.rhel7.x86_64
 postgresql13-contrib-13.7-1PGDG.rhel7.x86_64
 postgresql13-libs-13.7-1PGDG.rhel7.x86_64
 postgresql13-server-13.7-1PGDG.rhel7.x86_64
 $ rpm -qa | grep postgis* | sort
 postgis31_11-3.1.5-1.rhel7.x86_64
 postgis31_12-3.1.5-1.rhel7.x86_64
 postgis32_13-3.2.1-1.rhel7.x86_64
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5216>
