[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc1-25-g222c90799
Sat Aug 13 22:23:03 PDT 2022
the project "PostGIS".
       via  222c907991a3b416fbdfd74fe4bafcc281c5650d (commit)
       via  d1a31d89d9fa88619b69fd01dda35436951d0fcc (commit)
      from  6772f6c8c7ac7de6121f88896da106e275ab10b3 (commit)
revisions in full, below.
commit 222c907991a3b416fbdfd74fe4bafcc281c5650d
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Aug 14 01:22:57 2022 -0400
    Test new drone image, should have PG13 in it
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index da1e6e078..4fd3af33c 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -29,11 +29,11 @@ steps:
       - PGVER=11 sh ci/dronie/postgis_regress.sh
     depends_on: [ autogen ]
-  - name: build-12
+  - name: build-13
     image: *test-image
     pull: never
     commands:
-      - PGVER=12 sh ci/dronie/postgis_regress.sh
+      - PGVER=13 sh ci/dronie/postgis_regress.sh
   - name: build-docs
commit d1a31d89d9fa88619b69fd01dda35436951d0fcc
Date:   Sun Aug 14 01:21:51 2022 -0400
    Remove jenkins pipeline setup, needs some work
diff --git a/Jenkinsfile b/Jenkinsfile
deleted file mode 100644
index 4cf28ada4..000000000
--- a/Jenkinsfile
+++ /dev/null
@@ -1,20 +0,0 @@
-pipeline {
-    agent   {
-        label {
-            label 'jarmmie-drone'
-    stages {
-        stage('Build') {
-            steps {
-              sh './ci/debbie-pipeline/postgis_build.sh'
-        stage('Test') {
-            steps {
-                sh './ci/debbie-pipeline/postgis_regress.sh'
diff --git a/ci/debbie-pipeline/postgis_build.sh b/ci/debbie-pipeline/postgis_build.sh
deleted file mode 100755
index 89284f5ed..000000000
--- a/ci/debbie-pipeline/postgis_build.sh
+++ /dev/null
@@ -1,6 +0,0 @@
-export PG_VER=15
-export PGPATH=/usr/lib/postgresql/${PG_VER}
-export PATH=${PGPATH}/bin:${PATH}
-sh autogen.sh
-./configure
-make
diff --git a/ci/debbie-pipeline/postgis_regress.sh b/ci/debbie-pipeline/postgis_regress.sh
index 65725aefc..000000000
--- a/ci/debbie-pipeline/postgis_regress.sh
+++ /dev/null
@@ -1,55 +0,0 @@
-#!/usr/bin/env bash
-set -e
-## begin variables passed in by jenkins
-export PG_VER=15
-export MAKE_GARDEN=0
-export MAKE_EXTENSION=1
-export DUMP_RESTORE=0
-export MAKE_LOGBT=0
-export NO_SFCGAL=0
-export MAKE_UPGRADE=1
-make check
-## install so we can test upgrades/dump-restores etc.
-sudo make install
-if [ "$MAKE_EXTENSION" = "1" ]; then
- echo "Running extension testing"
- make check RUNTESTFLAGS="$RUNTESTFLAGS --extension"
- if [ "$?" != "0" ]; then
-  exit $?
- fi
-fi
-if [ "$DUMP_RESTORE" = "1" ]; then
- echo "Dum restore test"
- make check RUNTESTFLAGS="$RUNTESTFLAGS --dumprestore"
-  exit $?
- fi
-fi
-if [ "$MAKE_GARDEN" = "1" ]; then
- echo "Running garden test"
- make garden
-  exit $?
- fi
-fi
-# Test all available upgrades
-# TODO: protect via some variable ?
-if [ "$MAKE_UPGRADE" = "1" ]; then
- utils/check_all_upgrades.sh \
-        `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
-  exit $?
- fi
-fi
Summary of changes:
 .drone-1.0.yml                        |  4 +--
 Jenkinsfile                           | 20 -------------
 ci/debbie-pipeline/postgis_build.sh   |  6 ----
 ci/debbie-pipeline/postgis_regress.sh | 55 -----------------------------------
 4 files changed, 2 insertions(+), 83 deletions(-)
 delete mode 100644 Jenkinsfile
 delete mode 100755 ci/debbie-pipeline/postgis_build.sh
 delete mode 100755 ci/debbie-pipeline/postgis_regress.sh
hooks/post-receive
