[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on Proj 6.3 when points input are the same
PostGIS trac at osgeo.org
Mon Aug 15 14:18:51 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.7
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by pramsey):
 Important note: this error is on `ST_Length(geography)` not geometry, so
 the issue should have zero intersection with proj. That's a red herring.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:10>
