[postgis-tickets] [PostGIS] #5219: ./autogen.sh: You should run autoupdate
PostGIS trac at osgeo.org
Tue Aug 16 05:22:28 PDT 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  task                   |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"56bedcf33012d0762eadefb22b21f1df4156627c/git" 56bedcf/git]:
 {{{#!CommitTicketReference repository="git"
 revision="56bedcf33012d0762eadefb22b21f1df4156627c"
 Run autoupdate
 Closes #5219
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5219#comment:2>
