[postgis-tickets] [PostGIS] #5218: configure: error: could not find GDAL headers
PostGIS trac at osgeo.org
Tue Aug 16 08:34:24 PDT 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  invalid                |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Ok the problem was the configure script was picking the wrong gdal-config
 from /usr/local/bin, so this is invalid.
 For the record: the  gdal-config was a left-over from a manual `make
 uninstall` as the version of GDAL installed on the system (manually) did
 not have that rule, see
 https://github.com/OSGeo/gdal/issues/1446
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5218#comment:4>
