[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on Proj 6.3 when points input are the same
PostGIS trac at osgeo.org
Wed Aug 17 10:51:26 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.7
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by robe):
 No no need to report to PROJ.  I think the question was can we do similar
 to what we are doing with the non-geoid path that for linestrings where
 points are the same just return 0, do we need to error at all?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:14>
