[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on Proj 6.3 when points input are the same
PostGIS trac at osgeo.org
Wed Aug 17 13:49:04 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.7
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"f1c0c865a98fcd0eb89b4c0df645e695175dae58/git" f1c0c86/git]:
 {{{#!CommitTicketReference repository="git"
 revision="f1c0c865a98fcd0eb89b4c0df645e695175dae58"
 Short circuit geodesic distance when input points are equal (References
 #5171)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:17>
