[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on Proj 6.3 when points input are the same
PostGIS trac at osgeo.org
Wed Aug 17 19:16:22 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  high      |  Milestone:  PostGIS 2.5.9
 Component:  postgis   |    Version:  3.2.x
Resolution:  fixed     |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
 * milestone:  PostGIS 3.1.7 => PostGIS 2.5.9
Comment:
 I assume this is done, as branches 2.5-3.3 have the commit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:21>
