[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.6-32-gf30bed523
Wed Aug 17 23:16:28 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  f30bed5238db5d18af1e0afe8dc67c125ae487ec (commit)
      from  dfcc4326f5ff39e2d45896b290043387ab2fcb45 (commit)
revisions in full, below.
commit f30bed5238db5d18af1e0afe8dc67c125ae487ec
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Aug 18 02:16:23 2022 -0400
    Revert SELECT grep, caused regression in windows tests
diff --git a/regress/run_test.pl b/regress/run_test.pl
index aea1799f7..4709abd9a 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -800,7 +800,9 @@ sub run_simple_test
 	# Strip the lines we don't care about
 	@lines = grep(!/^\$/, @lines);
-	@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT [0-9]*|COPY|DO)$/, @lines);
+	## TODO: Figure out why this fails on windows
+	#@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT [0-9]*|COPY|DO)$/, @lines);
+	@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT|COPY|DO)/, @lines);
 	@lines = grep(!/^(CONTEXT|RESET|ANALYZE)/, @lines);
 	@lines = grep(!/^(DROP|CREATE|ALTER|VACUUM)/, @lines);
 	@lines = grep(!/^(LOG|SET|TRUNCATE|DISCARD)/, @lines);
Summary of changes:
 regress/run_test.pl | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
