[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.2-32-g81cbab46b
Thu Aug 18 00:47:54 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  81cbab46b4ceb37f706e3b3e5c0d1d1f06125a99 (commit)
      from  c0574b8104356a71a0bc3eebb49313f357d47b16 (commit)
revisions in full, below.
commit 81cbab46b4ceb37f706e3b3e5c0d1d1f06125a99
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Aug 18 08:24:34 2022 +0200
    run_test.pl: always pass --quiet to psql
    Removes the need to filter out lines ourselves from perl
diff --git a/regress/run_test.pl b/regress/run_test.pl
index aea1799f7..ee50ffdf1 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -723,7 +723,7 @@ sub drop_table
 sub sql
 	my $sql = shift;
-	my $result = `psql -tXA -d $DB -c 'SET search_path TO public,$OPT_SCHEMA' -c "$sql" | sed '/^SET\$/d'`;
+	my $result = `psql -qtXA -d $DB -c 'SET search_path TO public,$OPT_SCHEMA' -c "$sql" | sed '/^SET\$/d'`;
 	$result =~ s/[\n\r]*$//;
 	$result;
@@ -799,12 +799,6 @@ sub run_simple_test
 	close(FILE);
 	# Strip the lines we don't care about
-	@lines = grep(!/^\$/, @lines);
-	@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT [0-9]*|COPY|DO)$/, @lines);
-	@lines = grep(!/^(CONTEXT|RESET|ANALYZE)/, @lines);
-	@lines = grep(!/^(DROP|CREATE|ALTER|VACUUM)/, @lines);
-	@lines = grep(!/^(LOG|SET|TRUNCATE|DISCARD)/, @lines);
-	@lines = grep(!/^LINE \d/, @lines);
 	@lines = grep(!/^\s+$/, @lines);
 	# Morph values into expected forms
@@ -887,7 +881,7 @@ sub run_loader_and_check_output
 	my $errfile = "${TMPDIR}/loader.err";
 	# ON_ERROR_STOP is used by psql to return non-0 on an error
-	my $psql_opts = " --no-psqlrc --variable ON_ERROR_STOP=true";
+	my $psql_opts = " --quiet --no-psqlrc --variable ON_ERROR_STOP=true";
 	if ( $run_always || -r $expected_sql_file || -r $expected_select_results_file )
Summary of changes:
 regress/run_test.pl | 10 ++--------
 1 file changed, 2 insertions(+), 8 deletions(-)
hooks/post-receive
