[postgis-tickets] [PostGIS] #5221: function bytea(raster) is not a member of extension "postgis_raster" error when upgrading postgis 2.5.5 to 3.2.2
PostGIS trac at osgeo.org
Thu Aug 18 08:31:07 PDT 2022
  Reporter:  ryanfrench  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.2.3
 Component:  postgis     |    Version:  3.2.x
Resolution:              |   Keywords:
Description changed by ryanfrench:
Old description:
> When attempting to upgrade our Postgis extension from 2.5.5 to 3.2.2 the
> following error is shown. This has worked previously during tests when
> moving to both 3.2.1 and 3.2.2, but has started failing in the last 2
> weeks. The server is running on Ubuntu using the pgdg repository.
> SELECT public.postgis_extensions_upgrade();
> WARNING:  unpackaging raster
> WARNING:  PostGIS Raster functionality has been unpackaged
> HINT:  type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
> After upgrading, if you want to drop raster, run: DROP EXTENSION
> postgis_raster;
> NOTICE:  ALTER EXTENSION postgis UPDATE TO "3.2.2";
> d6l61m092figvj=# SELECT public.postgis_extensions_upgrade();
> NOTICE:  Extension postgis_sfcgal is not available or not packagable for
> some reason
> NOTICE:  Packaging extension postgis_raster
> ERROR:  function bytea(raster) is not a member of extension
> "postgis_raster"
> DETAIL:  An extension is not allowed to replace an object that it does
> not own.
> CONTEXT:  SQL statement "CREATE EXTENSION postgis_raster SCHEMA public
> VERSION unpackaged;ALTER EXTENSION postgis_raster UPDATE TO "3.2.2""
> PL/pgSQL function public.postgis_extensions_upgrade() line 71 at EXECUTE
New description:
 postgis_raster;
 some reason
 "postgis_raster"
 DETAIL:  An extension is not allowed to replace an object that it does not
 own.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5221#comment:1>
