[postgis-tickets] [PostGIS] #5188: heads-up: PROJ_LIB is now deprecated (use PROJ_DATA instead)
PostGIS trac at osgeo.org
Thu Aug 18 10:20:39 PDT 2022
  Reporter:  jmckenna     |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.3.0
 Component:  postgis      |    Version:  3.2.x
Resolution:  worksforme   |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => worksforme
Comment:
 I think that was needed in some CI when GDAL needed to know the PROJ_LIB.
 Since GDAL 3, which requires direct binding, that lib path I think is
 ignored.  But anyway not a PostGIS issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5188#comment:3>
