[postgis-tickets] [PostGIS] #5222: extension "postgis_raster" has no installation script nor update path for version "unpackaged"
PostGIS trac at osgeo.org
Fri Aug 19 15:11:44 PDT 2022
 Reporter:  marc3932        |      Owner:  robe
     Type:  patch           |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.2.3
Component:  raster          |    Version:  3.2.x
 Keywords:  postgis_raster  |
 Platform:
 Windows Server 2019 Standard
 PostgreSQL 11.17 x64
 SELECT postgis_full_version();
 "POSTGIS=""3.2.2 3.2.2"" [EXTENSION] PGSQL=""110""
 GEOS=""3.10.3-CAPI-1.16.1""
 PROJ=""7.2.1"" GDAL=""GDAL 2.2.4, released 2018/03/19 GDAL_DATA not
 found""
 LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
 (Internal)""
 **RASTER (raster lib from ""2.5.2 r17328"" need upgrade) [UNPACKAGED!]
 (raster procs from ""2.5.2 r17328"" need upgrade)"**
 ALTER EXTENSION postgis UPDATE;
 NOTICE:  version "3.2.2" of extension "postgis" is already installed
 ALTER EXTENSION
 Query returned successfully in 512 msec.
 SELECT postgis_extensions_upgrade();
 **NOTICE:  Extension postgis_sfcgal is not available or not packagable for
 some reason**
 **NOTICE:  Packaging extension postgis_raster
 **ERROR:  extension "postgis_raster" has no installation script nor update
 path for version "unpackaged"**
 **CONTEXT:  SQL statement "**
 **CREATE EXTENSION postgis_raster SCHEMA public
 VERSION unpackaged;**
 **ALTER EXTENSION postgis_raster UPDATE TO "3.2.2"**
 PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
 SQL state: 22023
 How can I upgrade to postgis_raster 3.2.2 ???
 If I don't have any raster data, then how do I remove pg_raster ???
 Thanks,
 Marcelo Marques
 | Principal Product Engineer | Esri | www.esri.com
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5222>
