[postgis-tickets] [PostGIS] #5222: extension "postgis_raster" has no installation script nor update path for version "unpackaged"
PostGIS trac at osgeo.org
Fri Aug 19 15:38:00 PDT 2022
  Reporter:  marc3932  |      Owner:  robe
      Type:  patch     |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.2.3
 Component:  raster    |    Version:  3.2.x
Resolution:            |   Keywords:  postgis_raster
Description changed by marc3932:
Old description:
> Platform:
> Windows Server 2019 Standard
> PostgreSQL 11.17 x64
> SELECT postgis_full_version();
> "POSTGIS=""3.2.2 3.2.2"" [EXTENSION] PGSQL=""110""
> GEOS=""3.10.3-CAPI-1.16.1""
> PROJ=""7.2.1"" GDAL=""GDAL 2.2.4, released 2018/03/19 GDAL_DATA not
> found""
> LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
> (Internal)""
> **RASTER (raster lib from ""2.5.2 r17328"" need upgrade) [UNPACKAGED!]
> (raster procs from ""2.5.2 r17328"" need upgrade)"**
> ALTER EXTENSION postgis UPDATE;
> NOTICE:  version "3.2.2" of extension "postgis" is already installed
> ALTER EXTENSION
> Query returned successfully in 512 msec.
> SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
> ''1 | "postgis" | "3.2.2" | "3.2.2" | "PostGIS geometry and geography
> spatial types and functions" |''
> SELECT postgis_extensions_upgrade();
> **NOTICE:  Extension postgis_sfcgal is not available or not packagable
> for some reason**
> **NOTICE:  Packaging extension postgis_raster
> **ERROR:  extension "postgis_raster" has no installation script nor
> update path for version "unpackaged"**
> **CONTEXT:  SQL statement "**
> **CREATE EXTENSION postgis_raster SCHEMA public
> VERSION unpackaged;**
> **ALTER EXTENSION postgis_raster UPDATE TO "3.2.2"**
> PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
> SQL state: 22023
> How can I upgrade to postgis_raster 3.2.2 ???
> If I don't have any raster data, then how do I remove pg_raster ???
> Thanks,
> Marcelo Marques
> | Principal Product Engineer | Esri | www.esri.com
New description:
 Platform:
 PostGIS 3.2.2
 found""
 (Internal)""
 ALTER EXTENSION
 **NOTICE:  Extension postgis_sfcgal is not available or not packagable for
 some reason**
 **ERROR:  extension "postgis_raster" has no installation script nor update
 SQL state: 22023
 Thanks,
 Marcelo Marques
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5222#comment:2>
