[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-3-g40a051601
Mon Aug 22 15:39:44 PDT 2022
the project "PostGIS".
       via  40a051601130f7c42243f6c616951977e384f278 (commit)
      from  4b9b65fd05b5421baa0a6e32e06dec3466f260a3 (commit)
revisions in full, below.
commit 40a051601130f7c42243f6c616951977e384f278
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Aug 22 15:39:40 2022 -0700
    Improve doc for MVT functions
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index ef1c1bfff..9cf04149a 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -916,9 +916,26 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
 		<refsection>
 			<title>Description</title>
-			<para>Creates a rectangular Polygon in <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> (SRID:3857) using the <ulink url="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</ulink>. By default, the bounds are the in EPSG:3857 using the standard range of the Web Mercator system (-20037508.342789, 20037508.342789). The optional bounds parameter can be used to generate envelopes for any tiling scheme: provide a geometry that has the SRID and extent of the initial "zoom level zero" square within which the tile system is to be inscribed.</para>
-			<para>The optional margin parameter can be used to grow a tile by the given percentage, e.g. margin=0.125 grows the tile by 12.5%, which is equivalent to buffer=512 when extent is 4096, as used in <xref linkend="ST_AsMVTGeom" />. This is useful to create a tile buffer -- to include data lying outside of the tile's visible area, but whose existence affects current tile's rendering. For example, a city name (a geopoint) could be near an edge of a tile, but the text would need to render on two tiles, even though the geopoint is located in the visible area of just one tile. Using an expanded tile in a search would include the city geopoint for both tiles. Use negative value to shrink the tile instead. Values less than -0.5 are prohibited because that would eliminate the tile completely. Do not use margin with ST_AsMVTGeom(). See example in <xref linkend="ST_AsMVT" />.</para>
+			<para>Creates a rectangular Polygon
+            giving the extent of a tile in the <ulink url="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</ulink>.
+            The tile is specifed by the zoom level Z and the XY index of the tile in the grid at that level.
+            Can be used to define the tile bounds required by <xref linkend="ST_AsMVTGeom" /> to convert geometry
+            into the MVT tile coordinate space.
+            </para>
+            <para>By default, the tile envelope is in the <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> coordinate system (SRID:3857)
+            using the standard range of the Web Mercator system (-20037508.342789, 20037508.342789).
+            This is the most common coordinate system used for MVT tiles.
+            The optional <varname>bounds</varname> parameter can be used to generate tiles in any coordinate system.
+            It is a geometry that has the SRID and extent of the "Zoom Level zero" square within which the XYZ tile system is inscribed.</para>
+			<para>The optional <varname>margin</varname> parameter can be used to expand a tile by the given percentage.
+            E.g. <varname>margin=0.125</varname> expands the tile by 12.5%, which is equivalent to buffer=512 when the tile extent size is 4096, as used in <xref linkend="ST_AsMVTGeom" />.
+            This is useful to create a tile buffer to include data lying outside of the tile's visible area, but whose existence affects the tile rendering.
+            For example, a city name (a point) could be near an edge of a tile, so its label should be rendered on two tiles, even though the point is located in the visible area of just one tile.
+            Using expanded tiles in a query will include the city point in both tiles.
+            Use a negative value to shrink the tile instead. Values less than -0.5 are prohibited because that would eliminate the tile completely.
+            Do not specify a margin when using with <varname>ST_AsMVTGeom</varname>.
+            See the example for <xref linkend="ST_AsMVT" />.</para>
 			<para>Enhanced: 3.1.0 Added margin parameter.</para>
 			<para>Availability: 3.0.0</para>
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index e07bc22c8..29b95d3d7 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1159,7 +1159,7 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refnamediv>
 		<refname>ST_AsMVTGeom</refname>
-		<refpurpose>Transform a geometry into the coordinate space of a <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink>.</refpurpose>
+		<refpurpose>Transforms a geometry into the coordinate space of a MVT tile.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
 		<funcsynopsis>
@@ -1177,15 +1177,27 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refsection>
-		<para>Transform a geometry into the coordinate space of a <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink> of a set of rows corresponding to a Layer.
-		Makes best effort to keep and even correct validity and might collapse geometry into a lower dimension in the process.
+		<para>Transforms a geometry into the coordinate space of a MVT (<ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink>) tile,
+        clipping it to the tile bounds if required.
+        The geometry must be in the coordinate system of the target map (using <xref linkend="ST_Transform" /> if needed).
+        Commonly this is <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> (SRID:3857).
+        </para>
+		<para>The function attempts to preserve geometry validity, and corrects it if needed.
+        This may cause the result geometry to collapse to a lower dimension.
 		</para>
-		<para><varname>geom</varname> is the geometry to transform.</para>
-		<para><varname>bounds</varname> is the geometric bounds of the tile contents without buffer.</para>
-		<para><varname>extent</varname> is the tile extent in tile coordinate space as defined by the <ulink url="https://www.mapbox.com/vector-tiles/specification/">specification</ulink>. If NULL it will default to 4096.</para>
-		<para><varname>buffer</varname> is the buffer distance in tile coordinate space to optionally clip geometries. If NULL it will default to 256.</para>
-		<para><varname>clip_geom</varname> is a boolean to control if geometries should be clipped or encoded as is. If NULL it will default to true.</para>
+        <para>The rectangular bounds of the tile in the target map coordinate space must be provided,
+        so the geometry can be transformed, and clipped if required.
+        The bounds can be generated using <xref linkend="ST_TileEnvelope" />.
+        </para>
+        <para>
+        This function is used to convert geometry into the tile coordinate space required by <xref linkend="ST_AsMVT" />.
+        </para>
+		<para><varname>geom</varname> is the geometry to transform, in the coordinate system of the target map.</para>
+		<para><varname>bounds</varname> is the rectangular bounds of the tile in map coordinate space, with no buffer.</para>
+		<para><varname>extent</varname> is the tile extent size in tile coordinate space as defined by the <ulink url="https://www.mapbox.com/vector-tiles/specification/">MVT specification</ulink>. Defaults to 4096.</para>
+		<para><varname>buffer</varname> is the buffer size in tile coordinate space for geometry clippig. Defaults to 256.</para>
+		<para><varname>clip_geom</varname> is a boolean to control if geometries are clipped or encoded as-is. Defaults to true.</para>
 		<para>Availability: 2.4.0</para>
@@ -1196,16 +1208,27 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refsection>
 		<title>Examples</title>
-		<programlisting><![CDATA[SELECT ST_AsText(ST_AsMVTGeom(
+		<programlisting>
+SELECT ST_AsText(ST_AsMVTGeom(
 	ST_GeomFromText('POLYGON ((0 0, 10 0, 10 5, 0 -5, 0 0))'),
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)),
 	4096, 0, false));
                               st_astext
  MULTIPOLYGON(((5 4096,10 4091,10 4096,5 4096)),((5 4096,0 4101,0 4096,5 4096)))
 		</programlisting>
+    <para>Canonical example for a Web Mercator tile using a computed tile bounds to query and clip geometry.
+    </para>
+		<programlisting>
+<![CDATA[SELECT ST_AsMVTGeom(
+            ST_Transform( geom, 3857 ),
+            ST_TileEnvelope(12, 513, 412), extent => 4096, buffer => 64) AS geom
+  FROM data
+  WHERE geom && ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096))
+</programlisting>
 	  </refsection>
     <refsection>
@@ -1222,7 +1245,7 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refnamediv>
 		<refname>ST_AsMVT</refname>
-		<refpurpose>Aggregate function returning a Mapbox Vector Tile representation of a set of rows.</refpurpose>
+		<refpurpose>Aggregate function returning a MVT representation of a set of rows.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
 		<funcsynopsis>
@@ -1264,8 +1287,8 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 		<para>An aggregate function which returns a binary <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink>
 		representation of a set of rows corresponding to a tile layer.
-		The rows should contain a geometry column which will be encoded as a feature geometry.
-		The geometry should be in tile coordinate space
+		The rows must contain a geometry column which will be encoded as a feature geometry.
+		The geometry must be in tile coordinate space
 		and valid as per the <ulink url="https://www.mapbox.com/vector-tiles/specification/">MVT specification</ulink>.
 		<xref linkend="ST_AsMVTGeom" /> can be used to transform geometry into tile coordinate space.
 		Other row columns are encoded as feature attributes.
Summary of changes:
 doc/reference_constructor.xml | 23 ++++++++++++++++---
 doc/reference_output.xml      | 53 +++++++++++++++++++++++++++++++------------
 2 files changed, 58 insertions(+), 18 deletions(-)
hooks/post-receive
