[postgis-tickets] [PostGIS] #5206: in_gml regression test fails
PostGIS trac at osgeo.org
Wed Aug 24 01:37:03 PDT 2022
  Reporter:  naziryavuz  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.5.9
 Component:  postgis     |    Version:  master
Resolution:              |   Keywords:
Comment (by naziryavuz):
 Replying to [comment:1 pramsey]:
 > At a minimum you need to include the output of `SELECT
 postgis_full_version()`. The error has something to do with your proj
 library in all likelihood.
 When I try to enable Postgis extension, it errors with: `could not access
 file "$libdir/postgis-3"`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5206#comment:3>
