[postgis-tickets] [PostGIS] #5224: Segmentation fault in ST_Covers
PostGIS trac at osgeo.org
Wed Aug 24 01:51:44 PDT 2022
 Reporter:  klette   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.2.4
Component:  postgis  |    Version:  3.2.x
 Keywords:           |
 Hi, we've been experiencing segmentation faults (signal 11) in production
 lately, so I have been trying to debug what's going on.
 The production query (ORM generated, so not the prettiest thing):
 SELECT "installercost_costmodelcoveredarea"."id",
        "installercost_costmodelcoveredarea"."name",
        "installercost_costmodelcoveredarea"."code",
        EXISTS(
         SELECT (1) AS "a"
           FROM "installercost_costmodelcoveredarea" U0
          INNER JOIN "installercost_costmodel_covered_areas" U1
             ON (U0."id" = U1."costmodelcoveredarea_id")
          WHERE (U1."costmodel_id" =
 'eddcec87-ae8c-4312-bb52-fac52c5c6ffe'::uuid AND NOT (U0."id" =
 "installercost_costmodelcoveredarea"."id") AND
 ST_Covers(ST_MakeValid(CAST(U0."geometry" AS geometry(GEOMETRY,4326))),
 ST_MakeValid(CAST("installercost_costmodelcoveredarea"."geometry" AS
 geometry(GEOMETRY,4326)))))
          LIMIT 1
        ) AS "has_encapsulating_parent"
     ON ("installercost_costmodelcoveredarea"."id" =
 "installercost_costmodel_covered_areas"."costmodelcoveredarea_id")
  WHERE "installercost_costmodel_covered_areas"."costmodel_id" =
  ORDER BY "installercost_costmodelcoveredarea"."code" ASC;
 As mentioned this crashes the server, but only on some input.
 I was able to reproduce the error locally using the production dataset,
 but I've not been able to create a minimal case.
 I created a stack trace in GDB with symbols, but I don't have a debug
 build available:
 Program received signal SIGSEGV, Segmentation fault.
 geos::geom::Envelope::intersects (this=0x55752ba7f550, other=...) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/include/geos/geom/Envelope.inl:237
 237         return (other.x <= maxx && other.x >= minx &&
 Missing separate debuginfos, use: dnf debuginfo-install
 libbrotli-1.0.9-7.fc36.x86_64 libnghttp2-1.46.0-2.fc36.x86_64
 #0  geos::geom::Envelope::intersects (this=0x55752ba7f550, other=...) at
 No locals.
 #1  0x00007fcd06f13a64 in
 geos::algorithm::locate::SimplePointInAreaLocator::locate (p=...,
 geom=0x55752ba63cd0) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/src/algorithm/locate/SimplePointInAreaLocator.cpp:50
 No locals.
 #2  0x00007fcd06f3149c in
 geos::algorithm::locate::SimplePointInAreaLocator::locate (p=<optimized
 out>, this=<synthetic pointer>) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/include/geos/algorithm/locate/SimplePointInAreaLocator.h:98
 No locals.
 #3
 geos::geom::prep::PreparedPolygonPredicate::isAnyTargetComponentInAreaTest
 (this=this at entry=0x7ffc73004da0, testGeom=testGeom at entry=0x55752ba63cd0,
 targetRepPts=0x55752ba7f860)
     at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/src/geom/prep/PreparedPolygonPredicate.cpp:164
         pt = <optimized out>
         loc = <optimized out>
         i = <optimized out>
         ni = 2
         piaLoc = <optimized out>
 #4  0x00007fcd06f354fb in
 geos::geom::prep::AbstractPreparedPolygonContains::eval
 (this=0x7ffc73004da0, geom=0x55752ba63cd0) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/src/geom/prep/AbstractPreparedPolygonContains.cpp:173
         isTargetInTestArea = <optimized out>
         outermostLoc = <optimized out>
         properIntersectionImpliesNotContained = true
 #5  0x00007fcd06f35627 in geos::geom::prep::PreparedPolygonCovers::covers
 (geom=0x55752ba63cd0, this=0x7ffc73004da0) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/include/geos/geom/prep/PreparedPolygonCovers.h:101
 No locals.
 #6  geos::geom::prep::PreparedPolygonCovers::covers (geom=0x55752ba63cd0,
 prep=0x55752ba7f850) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/include/geos/geom/prep/PreparedPolygonCovers.h:80
         polyInt = {<geos::geom::prep::AbstractPreparedPolygonContains> =
 {<geos::geom::prep::PreparedPolygonPredicate> =
 {_vptr.PreparedPolygonPredicate = 0x7fcd07085478 <vtable for
 geos::geom::prep::PreparedPolygonCovers+16>,
               prepPoly = 0x55752ba7f850}, hasSegmentIntersection = false,
 hasProperIntersection = false, hasNonProperIntersection = false,
 requireSomePointInInterior = false}, <No data fields>}
 #7  geos::geom::prep::PreparedPolygon::covers (g=0x55752ba63cd0,
 this=0x55752ba7f850) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/src/geom/prep/PreparedPolygon.cpp:124
 No locals.
 #8  geos::geom::prep::PreparedPolygon::covers (this=0x55752ba7f850,
 g=0x55752ba63cd0) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/src/geom/prep/PreparedPolygon.cpp:111
 No locals.
 #9  0x00007fcd07471a6b in operator() (__closure=<optimized out>) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/capi/geos_ts_c.cpp:3204
         pg = <optimized out>
         g = <optimized out>
         g = <optimized out>
 #10 execute<GEOSPreparedCovers_r(GEOSContextHandle_t, const
 geos::geom::prep::PreparedGeometry*, const
 geos::geom::Geometry*)::<lambda()> > (errval=2 '\002', f=...,
 extHandle=0x55752ba214a0)
     at /usr/src/debug/geos-3.10.2-4.fc36.x86_64/capi/geos_ts_c.cpp:384
         handle = 0x55752ba214a0
         handle = <optimized out>
         e = <optimized out>
 #11 GEOSPreparedCovers_r (extHandle=0x55752ba214a0, pg=<optimized out>,
 g=<optimized out>) at
 /usr/src/debug/geos-3.10.2-4.fc36.x86_64/capi/geos_ts_c.cpp:3203
 No locals.
 #12 0x00007fcd074db879 in covers (fcinfo=0x55752ba99948) at
 /usr/src/debug/postgis-3.2.2-1.fc36.x86_64/postgis/lwgeom_geos.c:2036
         g1 = 0x55752ba63cd0
         __errno_location = <optimized out>
         shared_geom1 = <optimized out>
         shared_geom2 = 0x55752ba96d50
         geom2 = 0x55752bb63208
         result = <optimized out>
         box1 = {flags = 4, xmin = 20.858917236328125, xmax =
 23.246383666992188, ymin = 50.534378051757812, ymax = 51.923946380615234,
 zmin = 6.9425600579334835e-310, zmax = 4.9406564584124654e-324, mmin =
 6.9425397015962754e-310,
           mmax = 6.7501224797414468e-319}
         box2 = {flags = 4, xmin = 21.325468063354492, xmax =
 21.860111236572266, ymin = 51.220718383789062, ymax = 51.500843048095703,
 zmin = 4.6423264247249451e-310, zmax = 4.64232637123226e-310, mmin =
 -1.3236840153589345e-282,
           mmax = 21.860111236572266}
         prep_cache = 0x55752baad0f0
         __func__ = "covers"
 #13 0x000055752983b55b in ExecInterpExpr (state=0x55752ba99008,
 econtext=0x55752ba5ac28, isnull=<optimized out>) at
 executor/execExprInterp.c:1260
         eqresult = <optimized out>
         fcinfo = <optimized out>
         op = <optimized out>
         resultslot = 0x0
         innerslot = <optimized out>
         outerslot = <optimized out>
         scanslot = 0x55752ba5acb8
         dispatch_table = {0x55752983b2cc <ExecInterpExpr+268>,
 0x55752983b750 <ExecInterpExpr+1424>, 0x55752983b728
 <ExecInterpExpr+1384>, 0x55752983b700 <ExecInterpExpr+1344>,
 0x55752983b6d0 <ExecInterpExpr+1296>,
           0x55752983c2f0 <ExecInterpExpr+4400>, 0x55752983b6a0
 <ExecInterpExpr+1248>, 0x55752983b660 <ExecInterpExpr+1184>,
 0x55752983c2e0 <ExecInterpExpr+4384>, 0x55752983b680
 <ExecInterpExpr+1216>,
           0x55752983b640 <ExecInterpExpr+1152>, 0x55752983b600
 <ExecInterpExpr+1088>, 0x55752983c2c8 <ExecInterpExpr+4360>,
 0x55752983c2a0 <ExecInterpExpr+4320>, 0x55752983b5d8
 <ExecInterpExpr+1048>, 0x55752983b5a0 <ExecInterpExpr+992>,
           0x55752983b578 <ExecInterpExpr+952>, 0x55752983b548
 <ExecInterpExpr+904>, 0x55752983b510 <ExecInterpExpr+848>, 0x55752983b4f0
 <ExecInterpExpr+816>, 0x55752983b4d0 <ExecInterpExpr+784>, 0x55752983b240
 <ExecInterpExpr+128>,
           0x55752983b24b <ExecInterpExpr+139>, 0x55752983b490
 <ExecInterpExpr+720>, 0x55752983b280 <ExecInterpExpr+192>, 0x55752983b28b
 <ExecInterpExpr+203>, 0x55752983c268 <ExecInterpExpr+4264>, 0x55752983c220
 <ExecInterpExpr+4192>,
           0x55752983c230 <ExecInterpExpr+4208>, 0x55752983b3a0
 <ExecInterpExpr+480>, 0x55752983c200 <ExecInterpExpr+4160>, 0x55752983c1e8
 <ExecInterpExpr+4136>, 0x55752983c1c0 <ExecInterpExpr+4096>,
 0x55752983c198 <ExecInterpExpr+4056>,
           0x55752983c170 <ExecInterpExpr+4016>, 0x55752983c158
 <ExecInterpExpr+3992>, 0x55752983c140 <ExecInterpExpr+3968>,
 0x55752983c120 <ExecInterpExpr+3936>, 0x55752983c0d0
 <ExecInterpExpr+3856>,
           0x55752983c0a0 <ExecInterpExpr+3808>, 0x55752983c100
 <ExecInterpExpr+3904>, 0x55752983c060 <ExecInterpExpr+3744>,
 0x55752983c040 <ExecInterpExpr+3712>, 0x55752983c030
 <ExecInterpExpr+3696>,
           0x55752983c000 <ExecInterpExpr+3648>, 0x55752983bfb0
 <ExecInterpExpr+3568>, 0x55752983bf60 <ExecInterpExpr+3488>,
 0x55752983bf20 <ExecInterpExpr+3424>, 0x55752983bee8
 <ExecInterpExpr+3368>,
           0x55752983be68 <ExecInterpExpr+3240>, 0x55752983bed0
 <ExecInterpExpr+3344>, 0x557529634864 <ExecInterpExpr-2124124>,
 0x55752983bdf8 <ExecInterpExpr+3128>, 0x55752983bde0
 <ExecInterpExpr+3104>,
           0x55752983be10 <ExecInterpExpr+3152>, 0x55752983be50
 <ExecInterpExpr+3216>, 0x55752983bda8 <ExecInterpExpr+3048>,
 0x55752983bd58 <ExecInterpExpr+2968>, 0x55752983bd40
 <ExecInterpExpr+2944>,
           0x55752983bd20 <ExecInterpExpr+2912>, 0x55752983bce0
 <ExecInterpExpr+2848>, 0x55752983bd00 <ExecInterpExpr+2880>,
 0x55752983bcc0 <ExecInterpExpr+2816>, 0x55752983bcb0
 <ExecInterpExpr+2800>, 0x55752983b220 <ExecInterpExpr+96>,
           0x55752983b224 <ExecInterpExpr+100>, 0x55752983bfd0
 <ExecInterpExpr+3600>, 0x55752983bba0 <ExecInterpExpr+2528>,
 0x55752983bb78 <ExecInterpExpr+2488>, 0x55752983bc98
 <ExecInterpExpr+2776>, 0x55752983bc80 <ExecInterpExpr+2752>,
           0x55752983bc48 <ExecInterpExpr+2696>, 0x55752983bb60
 <ExecInterpExpr+2464>, 0x55752983bc60 <ExecInterpExpr+2720>,
 0x55752983bb48 <ExecInterpExpr+2440>, 0x55752983bc10
 <ExecInterpExpr+2640>,
           0x55752983bbc0 <ExecInterpExpr+2560>, 0x55752983b308
 <ExecInterpExpr+328>, 0x55752983b316 <ExecInterpExpr+342>, 0x55752983bb10
 <ExecInterpExpr+2384>, 0x55752983baa0 <ExecInterpExpr+2272>,
 0x55752983bae0 <ExecInterpExpr+2336>,
           0x55752983b3b0 <ExecInterpExpr+496>, 0x55752983ba70
 <ExecInterpExpr+2224>, 0x55752983b9c0 <ExecInterpExpr+2048>,
 0x55752983b8c8 <ExecInterpExpr+1800>, 0x55752983b890
 <ExecInterpExpr+1744>, 0x55752983b7b0 <ExecInterpExpr+1520>,
           0x55752983b780 <ExecInterpExpr+1472>, 0x55752983b470
 <ExecInterpExpr+688>, 0x55752983b2c8 <ExecInterpExpr+264>}
 #14 0x000055752984cc27 in ExecEvalExprSwitchContext
 (isNull=0x7ffc73004f87, econtext=0x55752ba5ac28, state=0x55752ba99008) at
 access/heap/../../../../src/include/executor/executor.h:339
         retDatum = <optimized out>
         oldContext = 0x55752ba58e20
 #15 ExecQual (econtext=0x55752ba5ac28, state=0x55752ba99008) at
 access/heap/../../../../src/include/executor/executor.h:408
         ret = <optimized out>
         isnull = false
 #16 ExecScan (node=0x55752ba5aa18, accessMtd=0x5575298667d0 <IndexNext>,
 recheckMtd=0x55752985f050 <IndexRecheck>) at executor/execScan.c:227
         econtext = 0x55752ba5ac28
         qual = 0x55752ba99008
         projInfo = 0x55752ba98768
 #17 0x0000557529845e7c in ExecProcNodeInstr (node=0x55752ba5aa18) at
 executor/execProcnode.c:479
 #18 0x000055752986bca5 in ExecProcNode (node=0x55752ba5aa18) at
 executor/../../../src/include/executor/executor.h:257
 No locals.
 #19 ExecMemoize (pstate=0x55752ba5a778) at executor/nodeMemoize.c:743
         entry = <optimized out>
         found = <optimized out>
         node = 0x55752ba5a778
         outerNode = 0x55752ba5aa18
         __func__ = "ExecMemoize"
 #20 0x0000557529845e7c in ExecProcNodeInstr (node=0x55752ba5a778) at
 #21 0x00005575298733f8 in ExecProcNode (node=0x55752ba5a778) at
 No locals.
 #22 ExecNestLoop (pstate=<optimized out>) at executor/nodeNestloop.c:160
         node = <optimized out>
         nl = 0x55752ba76918
         innerPlan = 0x55752ba5a778
         outerPlan = 0x55752ba59418
         outerTupleSlot = <optimized out>
         innerTupleSlot = <optimized out>
         joinqual = 0x0
         otherqual = <optimized out>
         econtext = 0x55752ba59338
         lc = <optimized out>
 #23 0x0000557529845e7c in ExecProcNodeInstr (node=0x55752ba59228) at
 #24 0x0000557529877b53 in ExecProcNode (node=0x55752ba59228) at
 No locals.
 #25 ExecScanSubPlan (isNull=0x55752baa9c7d, econtext=0x55752ba9e160,
 node=<optimized out>) at executor/nodeSubplan.c:323
         found = false
         astate = 0x0
         subplan = 0x55752ba8eeb8
         subLinkType = <optimized out>
         planstate = 0x55752ba59228
         oldcontext = 0x55752baa25d0
         result = 0
         pvar = <optimized out>
         l = <optimized out>
         subplan = <optimized out>
         planstate = <optimized out>
         oldcontext = <optimized out>
         l = <optimized out>
         astate = <optimized out>
         __func__ = <optimized out>
         estate = <optimized out>
         l__state = <optimized out>
         paramid = <optimized out>
         prm = <optimized out>
         tdesc = <optimized out>
         rowresult = <optimized out>
         rownull = <optimized out>
         col = <optimized out>
         plst = <optimized out>
         dvalue = <optimized out>
         disnull = <optimized out>
         plst__state = <optimized out>
         prmdata = <optimized out>
 #26 ExecSubPlan (node=<optimized out>, econtext=0x55752ba9e160,
 isNull=0x55752baa9c7d) at executor/nodeSubplan.c:89
         estate = 0x55752ba58f38
         dir = ForwardScanDirection
         retval = <optimized out>
         __func__ = "ExecSubPlan"
 #27 0x000055752983bc0a in ExecEvalSubPlan (econtext=0x55752ba9e160,
 op=<optimized out>, state=0x55752baa9c78) at
 executor/execExprInterp.c:3932
         sstate = <optimized out>
 #28 ExecInterpExpr (state=0x55752baa9c78, econtext=0x55752ba9e160,
 isnull=<optimized out>) at executor/execExprInterp.c:1564
         resultslot = 0x55752baa9be0
         scanslot = 0x0
 #29 0x0000557529873699 in ExecEvalExprSwitchContext
 (isNull=0x7ffc73005297, econtext=0x55752ba9e160, state=0x55752baa9c78) at
 executor/../../../src/include/executor/executor.h:339
         oldContext = <optimized out>
 #30 ExecProject (projInfo=0x55752baa9c70) at
 executor/../../../src/include/executor/executor.h:373
         econtext = 0x55752ba9e160
         state = 0x55752baa9c78
         isnull = false
 #31 ExecNestLoop (pstate=<optimized out>) at executor/nodeNestloop.c:241
         nl = 0x55752ba8de18
         innerPlan = <optimized out>
         outerPlan = 0x55752ba9e280
         joinqual = 0x0
         econtext = <optimized out>
 #32 0x0000557529845e7c in ExecProcNodeInstr (node=0x55752ba9e050) at
 #33 0x0000557529876b88 in ExecProcNode (node=0x55752ba9e050) at
 No locals.
 #34 ExecSort (pstate=0x55752ba9de40) at executor/nodeSort.c:108
         plannode = <optimized out>
         outerNode = 0x55752ba9e050
         tupDesc = <optimized out>
         si = <optimized out>
         tuplesortstate = 0x55752bab9248
 #35 0x0000557529845e7c in ExecProcNodeInstr (node=0x55752ba9de40) at
 #36 0x000055752983f262 in ExecProcNode (node=0x55752ba9de40) at
 No locals.
 #37 ExecutePlan (execute_once=<optimized out>, dest=0x557529e0f820
 <donothingDR.lto_priv.0>, direction=<optimized out>, numberTuples=0,
 sendTuples=true, operation=CMD_SELECT, use_parallel_mode=<optimized out>,
 planstate=0x55752ba9de40,
     estate=0x55752ba58f38) at executor/execMain.c:1551
         current_tuple_count = 0
         current_tuple_count = <optimized out>
 #38 standard_ExecutorRun (queryDesc=0x55752ba90b48, direction=<optimized
 out>, count=0, execute_once=<optimized out>) at executor/execMain.c:361
         operation = CMD_SELECT
         dest = 0x557529e0f820 <donothingDR.lto_priv.0>
         sendTuples = <optimized out>
         oldcontext = 0x55752b911960
         __func__ = "standard_ExecutorRun"
 #39 0x00005575297d3395 in ExecutorRun (execute_once=true, count=0,
 direction=<optimized out>, queryDesc=0x55752ba90b48) at
 executor/execMain.c:305
 No locals.
 #40 ExplainOnePlan (plannedstmt=plannedstmt at entry=0x55752ba90ab8,
 into=into at entry=0x0, es=es at entry=0x55752ba368b8,
     queryString=queryString at entry=0x55752b94ffb8 "explain analyze SELECT
 \"installercost_costmodelcoveredarea\".\"id\",\n
 \"installercost_costmodelcoveredarea\".\"name\",\n
 \"installercost_costmodelcoveredarea\".\"code\",\n       EXISTS(\n
 SELECT "..., params=params at entry=0x0, queryEnv=queryEnv at entry=0x0,
 planduration=0x7ffc730054a0, bufusage=0x0) at commands/explain.c:593
         dir = <optimized out>
         dest = <optimized out>
         queryDesc = 0x55752ba90b48
         starttime = {tv_sec = 193212, tv_nsec = 771271060}
         totaltime = 0
         eflags = <optimized out>
         instrument_option = <optimized out>
 #41 0x00005575297d3502 in ExplainOneQuery (query=<optimized out>,
 cursorOptions=<optimized out>, into=0x0, es=0x55752ba368b8,
     queryString=0x55752b94ffb8 "explain analyze SELECT
 SELECT "..., params=0x0, queryEnv=0x0) at commands/explain.c:410
         planstart = {tv_sec = 193212, tv_nsec = 769857899}
         bufusage = {shared_blks_hit = 140518568650264, shared_blks_read =
 140722237887724, shared_blks_dirtied = 93961731534232, shared_blks_written
 = 93961699012838, local_blks_hit = 3, local_blks_read = 140518568650264,
           local_blks_dirtied = 140518568650264, local_blks_written =
 93961730936936, temp_blks_read = 93961731534232, temp_blks_written =
 140518568650264, blk_read_time = {tv_sec = 93961731539864, tv_nsec =
 93961698978814},
           blk_write_time = {tv_sec = 93961731535928, tv_nsec = 2}}
         plan = 0x55752ba90ab8
         planduration = {tv_sec = 0, tv_nsec = 1413018}
         bufusage_start = {shared_blks_hit = 0, shared_blks_read =
 93961697415532, shared_blks_dirtied = 140722237887862, shared_blks_written
 = 140722237887864, local_blks_hit = 127, local_blks_read = 4294967096,
 local_blks_dirtied = 64,
           local_blks_written = 93961730464096, temp_blks_read = 0,
 temp_blks_written = 93961731534232, blk_read_time = {tv_sec =
 93961731774216, tv_nsec = 93961699241537}, blk_write_time = {tv_sec =
 2048, tv_nsec = 0}}
 #42 0x00005575297d3921 in ExplainQuery (pstate=<optimized out>,
 stmt=0x55752ba16b38, params=0x0, dest=0x55752b911ba0) at
 commands/explain.c:281
         l__state = {l = <optimized out>, i = 0}
         l = 0x55752ba51770
         es = 0x55752ba368b8
         tstate = <optimized out>
         jstate = <optimized out>
         query = <optimized out>
         rewritten = 0x55752ba51758
         timing_set = <optimized out>
         summary_set = <optimized out>
         __func__ = "ExplainQuery"
 #43 0x00005575299da03b in standard_ProcessUtility (pstmt=0x55752ba28030,
 SELECT "..., readOnlyTree=<optimized out>,
 context=PROCESS_UTILITY_TOPLEVEL, params=0x0, queryEnv=0x0,
 dest=0x55752b911ba0, qc=0x7ffc73005760) at tcop/utility.c:862
         parsetree = 0x55752ba16b38
         isTopLevel = <optimized out>
         isAtomicContext = false
         pstate = 0x55752b911c30
         readonly_flags = <optimized out>
         __func__ = "standard_ProcessUtility"
 #44 0x00005575299da65c in ProcessUtility (qc=0x7ffc73005760,
 dest=0x55752b911ba0, queryEnv=<optimized out>, params=<optimized out>,
 context=PROCESS_UTILITY_TOPLEVEL, readOnlyTree=<optimized out>,
 queryString=<optimized out>,
     pstmt=0x55752ba28030) at tcop/utility.c:527
 No locals.
 #45 PortalRunUtility (portal=portal at entry=0x55752b9bdb48,
 pstmt=0x55752ba28030, isTopLevel=isTopLevel at entry=true,
 setHoldSnapshot=setHoldSnapshot at entry=true,
 dest=dest at entry=0x55752b911ba0, qc=qc at entry=0x7ffc73005760)
     at tcop/pquery.c:1155
 No locals.
 #46 0x00005575299daa67 in FillPortalStore (portal=0x55752b9bdb48,
 isTopLevel=<optimized out>) at tcop/pquery.c:1028
         treceiver = 0x55752b911ba0
         qc = {commandTag = CMDTAG_UNKNOWN, nprocessed = 0}
         __func__ = "FillPortalStore"
 #47 0x00005575299dad9d in PortalRun (portal=0x55752b9bdb48,
 count=9223372036854775807, isTopLevel=<optimized out>, run_once=<optimized
 out>, dest=0x55752ba28c00, altdest=0x55752ba28c00, qc=0x7ffc73005940) at
 tcop/pquery.c:760
         _save_exception_stack = 0x7ffc73005d20
         _save_context_stack = 0x0
         _local_sigjmp_buf = {{__jmpbuf = {1, 6863867129712395464,
 93961731169096, 0, 93961731607552, 93961731533880, 6863867130152797384,
 744202186752050376}, __mask_was_saved = 0, __saved_mask = {__val =
 {93960999534592, 1, 1, 1,
                 93961699240471, 1, 93961731169096, 93961700891012,
 93961731177304, 112, 93961730717312, 93961731169096, 0, 0, 93961699242721,
 0}}}}
         _do_rethrow = <optimized out>
         nprocessed = <optimized out>
         saveTopTransactionResourceOwner = 0x55752b97f270
         saveTopTransactionContext = 0x55752b9fbba0
         saveActivePortal = 0x0
         saveResourceOwner = 0x55752b97f270
         savePortalContext = 0x0
         saveMemoryContext = 0x55752b9fbba0
         __func__ = "PortalRun"
 #48 0x00005575299d2fe5 in exec_simple_query (
     query_string=0x55752b94ffb8 "explain analyze SELECT
 SELECT "...) at tcop/postgres.c:1214
         fportal = <optimized out>
         snapshot_set = <optimized out>
         per_parsetree_context = 0x0
         plantree_list = 0x55752ba295a0
         stmt = <optimized out>
         parsetree = 0x55752ba16c08
         commandTag = <optimized out>
         querytree_list = <optimized out>
         portal = 0x55752b9bdb48
         receiver = 0x55752ba28c00
         format = <optimized out>
         parsetree_item__state = {l = 0x55752ba16c38, i = 0}
         oldcontext = 0x55752b9fbba0
         parsetree_list = 0x55752ba16c38
         parsetree_item = <optimized out>
         save_log_statement_stats = false
         was_logged = false
         use_implicit_block = false
         msec_str =
 "\000\000\000\000\002\000\000\000\v\000\000\000\260\232h\205\000\000\000\000\000\000\000\000\265\227\ts\374\177\000"
         __func__ = "exec_simple_query"
 #49 0x00005575299d5b69 in PostgresMain (argc=<optimized out>,
 argv=<optimized out>, dbname=<optimized out>, username=<optimized out>) at
 tcop/postgres.c:4496
         query_string = 0x55752b94ffb8 "explain analyze SELECT
 SELECT "...
         firstchar = <optimized out>
         input_message = {
           data = 0x55752b94ffb8 "explain analyze SELECT
 SELECT "..., len = 1141, maxlen = 2048, cursor = 1141}
         local_sigjmp_buf = {{__jmpbuf = {140722237889472,
 744197743274935496, 0, 140722237890432, 93961702288928, 243,
 6863867129695618248, 744202194557125832}, __mask_was_saved = 1,
 __saved_mask = {__val = {4194304, 74, 93961730722392,
                 93961730722392, 1, 5, 93961697153692, 93961730880016, 0,
 844424930132128, 93961730717312, 714642157761220, 343597383680,
 140722237890432, 93961702288928, 1024}}}}
         send_ready_for_query = false
         idle_in_transaction_timeout_enabled = false
         idle_session_timeout_enabled = false
         __func__ = "PostgresMain"
 #50 0x00005575299520c8 in BackendRun (port=0x55752b977210) at
 postmaster/postmaster.c:4530
         av = {0x557529ba754a "postgres", 0x0}
         ac = 1
         av = <optimized out>
         ac = <optimized out>
 #51 BackendStartup (port=0x55752b977210) at postmaster/postmaster.c:4252
         bn = <optimized out>
         pid = 0
         pid = <optimized out>
         save_errno = <optimized out>
 #52 ServerLoop () at postmaster/postmaster.c:1745
         port = 0x55752b977210
         i = <optimized out>
         rmask = {fds_bits = {256, 0 <repeats 15 times>}}
         selres = <optimized out>
         now = <optimized out>
         readmask = {fds_bits = {960, 0 <repeats 15 times>}}
         nSockets = <optimized out>
         last_lockfile_recheck_time = 1661326898
         last_touch_time = 1661324618
         __func__ = "ServerLoop"
 #53 0x0000557529952df1 in PostmasterMain (argc=<optimized out>,
 argv=0x55752b90a810) at postmaster/postmaster.c:1417
         opt = <optimized out>
         status = <optimized out>
         userDoption = <optimized out>
         listen_addr_saved = <optimized out>
         i = <optimized out>
         output_config_variable = <optimized out>
         __func__ = "PostmasterMain"
 #54 0x000055752967ae6e in main (argc=3, argv=0x55752b90a810) at
 main/main.c:209
         do_check_root = <optimized out>
 Inspecting the memory I've extracted the two geometries (MultiPolygons).
 I have attached them, as one of the is quite large.
 The only, maybe, smoking gun is that the last MultiPolygon has it's last
 element as EMPTY. So that might be something.
 I've tried all combinations of ST_Cover-calls using these two geometries,
 but I'm not able to reproduce the crash outside of the query posted above.
 So maybe some optimization passing in a nullptr?
 I've tried disabling both JIT and parallel workers, but to no avail.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5224>
