[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.0rc2-5-g4464fea52
Fri Aug 26 14:35:22 PDT 2022
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  4464fea52902bdae4fc33cf9870d3043faa01080 (commit)
       via  1550fcc70ee5d9183a5f12a54a87f11006faa7c6 (commit)
       via  97892fae085de30dad5ba4d6a6051516262962be (commit)
      from  337354f3ad30c4739d30d9c01d414f6345d906d4 (commit)
revisions in full, below.
commit 4464fea52902bdae4fc33cf9870d3043faa01080
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Aug 26 17:35:16 2022 -0400
    Prepping for release
diff --git a/NEWS b/NEWS
index 83d901459..fd8a1ec8a 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,78 @@
+PostGIS 3.3.0
+2022/08/26
+This version requires PostgreSQL 11 or higher, GEOS 3.6 or higher, and Proj 5.2+.
+Additional features are enabled if you are running GEOS 3.9+
+ST_MakeValid enhancements with 3.10+, ST_ConcaveHull and several other enhancements with GEOS 3.11+.
+Requires SFCGAL 1.4.1+ for ST_AlphaShape and ST_OptimalAlphaShape.
+The new --enable-lto flag improves math computations.  This new feature is disabled by default
+because on some platforms, causes compilation errors (BSD and MingW64 issues have been raised)
+Use below to enable it.
+ ./configure --enable-lto flag
+ * New features *
+  - #5116, Topology export/import scripts (Sandro Santilli)
+  - ST_Letters creates geometries that look like letters (Paul Ramsey)
+  - #5037, postgis_sfcgal: ST_3DConvexHull (Loïc Bartoletti)
+  - postgis_sfcgal: sfcgal_full_version - reports BOOST and CGAL version
+    (Loïc Bartoletti)
+  - GH659, MARC21/XML, ST_GeomFromMARC21, ST_AsMARC21 (Jim Jones)
+  - #5132, GH683, sfcgal: ST_3DUnion aggregate function (Sergei Shoulbakov)
+  - #5143, SFCGAL ST_AlphaShape and ST_OptimalAlphaShape
+           Requires SFCGAL 1.4.1+ (Loïc Bartoletti)
+  - #5162, ST_TriangulatePolygon with GEOS 3.11+ (Paul Ramsey, Martin Davis)
+  - #5162, ST_SimplifyPolygonHull with GEOS 3.11+ (Paul Ramsey, Martin Davis)
+  - #5183, topology.RemoveUnusedPrimitives (Sandro Santilli)
+ * Breaking changes *
+  - Drop support for PostgreSQL 9.6 and 10 (Regina Obe)
+  - Change output for WKT MULTIPOINT. All points now
+    wrapped in parens. (Even Roualt)
+  - GH674, geometry validation and fixing is disabled
+    for ST_DumpAsPolygons and ST_Polygon so it works faster
+    but might produce invalid polygons. (Aliaksandr Kalenik)
+ * Enhancements *
+  - #2861, Add index on topology.node(containing_face) speeding up
+    splitting and merging of faces (Sandro Santilli)
+  - #2083, Speed up ST_RemEdge topology functions adding index on
+    relation(element_id) and edge_data(abs_next*) (Sandro Santilli)
+  - #5118, Allow dropping topologies with missing topogeometry sequences
+    (Sandro Santilli)
+  - #5111, faster topology face MBR computation (Sandro Santilli)
+  - postgis_extensions_upgrade() support for upgrades from any PostGIS
+    version, including yet to be released ones (Sandro Santilli)
+  - #5040, add postgis_sfcgal_full_version (Loïc Bartoletti)
+  - GH655, GiST: balance the tree splits better in recursive calls (Darafei Praliaskouski)
+  - GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
+  - #4939, #5161, ST_LineMerge now has option to keep the directions of input linestrings,
+    useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)
+  - ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
+  - ST_ConcaveHull GEOS 3.11+ polygon-respecting native implementation (Paul Ramsey, Martin Davis)
+  - #4574, GH678, #5121 Enable Link-Time Optimizations using --enable-lto (Sergei Shoulbakov)
+  - GH676, faster ST_Clip (Aliaksandr Kalenik)
+  - #5135, Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)
+  - #5158, pgtopo_import / pgtopo_export manpages (Sandro Santilli)
+  - #5170, add a optional max_rows_per_copy to -Y option to raster2pgsql to
+    control number of rows per copy statement.
+    Default to 50 when not specified (Regina Obe)
+  - GH698, support parallel aggregate for ST_Union (Sergei Shoulbakov)
+  - #5024, Update spatial_ref_sys as part of ALTER EXTENSION update postgis (Paul Ramsey)
+ * Bug Fix *
+   These are fixes not backported to older minors
+   - #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
+   - #5088, Memory corruption in mvt_agg_transfn (Victor Collod)
+   - #5137, resetting interrupt flags before query execution (Sergei Shoulbakov)
+   - #5148, ST_Clip is more robust to alignment of raster and clip geometry (Sergei Shoulbakov)
+   - #4932, Bug with geography ST_Intersects / ST_Distance (Paul Ramsey)
+   - #5089, ST_Reverse also reverses components of CompoundCurve (Paul Ramsey)
 PostGIS 3.3.0rc2
 2022/08/21
@@ -94,81 +169,6 @@ Changes since PostGIS 3.3.0alpha1
   - #5114, pgsql2shp segfault with long or many truncated columns
-PostGIS 3.3.0dev
-2022/xx/xx
-This version requires PostgreSQL 11 or higher, GEOS 3.6 or higher, and Proj 5.2+.
-Additional features are enabled if you are running GEOS 3.9+
-ST_MakeValid enhancements with 3.10+, ST_ConcaveHull and several other enhancements with GEOS 3.11+.
-The new --enable-lto flag improves math computations.  This new feature is disabled by default
-because on some platforms, causes compilation errors (BSD and MingW64 issues have been raised)
-Use below to enable it.
- ./configure --enable-lto flag
- * Breaking changes *
-  - Drop support for PostgreSQL 9.6 and 10 (Regina Obe)
-  - Change output for WKT MULTIPOINT. All points now
-    wrapped in parens. (Even Roualt)
-  - GH674, geometry validation and fixing is disabled
-    for ST_DumpAsPolygons and ST_Polygon so it works faster
-    but might produce invalid polygons. (Aliaksandr Kalenik)
- * Enhancements *
-  - #2861, Add index on topology.node(containing_face) speeding up
-    splitting and merging of faces (Sandro Santilli)
-  - #2083, Speed up ST_RemEdge topology functions adding index on
-    relation(element_id) and edge_data(abs_next*) (Sandro Santilli)
-  - #5118, Allow dropping topologies with missing topogeometry sequences
-    (Sandro Santilli)
-  - #5111, faster topology face MBR computation (Sandro Santilli)
-  - postgis_extensions_upgrade() support for upgrades from any PostGIS
-    version, including yet to be released ones (Sandro Santilli)
-  - #5040, add postgis_sfcgal_full_version (Loïc Bartoletti)
-  - GH655, GiST: balance the tree splits better in recursive calls (Darafei Praliaskouski)
-  - GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
-  - #4939, #5161, ST_LineMerge now has option to keep the directions of input linestrings,
-    useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)
-  - ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
-  - ST_ConcaveHull GEOS 3.11+ polygon-respecting native implementation (Paul Ramsey, Martin Davis)
-  - #4574, GH678, #5121 Enable Link-Time Optimizations using --enable-lto (Sergei Shoulbakov)
-  - GH676, faster ST_Clip (Aliaksandr Kalenik)
-  - #5135, Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)
-  - #5158, pgtopo_import / pgtopo_export manpages (Sandro Santilli)
-  - #5170, add a optional max_rows_per_copy to -Y option to raster2pgsql to
-    control number of rows per copy statement.
-    Default to 50 when not specified (Regina Obe)
-  - GH698, support parallel aggregate for ST_Union (Sergei Shoulbakov)
-  - #5024, Update spatial_ref_sys as part of ALTER EXTENSION update postgis (Paul Ramsey)
- * New features *
-  - #5116, Topology export/import scripts (Sandro Santilli)
-  - ST_Letters creates geometries that look like letters (Paul Ramsey)
-  - #5037, postgis_sfcgal: ST_3DConvexHull (Loïc Bartoletti)
-  - postgis_sfcgal: sfcgal_full_version - reports BOOST and CGAL version
-    (Loïc Bartoletti)
-  - GH659, MARC21/XML, ST_GeomFromMARC21, ST_AsMARC21 (Jim Jones)
-  - #5132, GH683, sfcgal: ST_3DUnion aggregate function (Sergei Shoulbakov)
-  - #5143, SFCGAL ST_AlphaShape and ST_OptimalAlphaShape
-           Requires SFCGAL 1.4.1+ (Loïc Bartoletti)
-  - #5162, ST_TriangulatePolygon with GEOS 3.11+ (Paul Ramsey, Martin Davis)
-  - #5162, ST_SimplifyPolygonHull with GEOS 3.11+ (Paul Ramsey, Martin Davis)
-  - #5183, topology.RemoveUnusedPrimitives (Sandro Santilli)
- * Bug Fix *
-   - #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
-   - #5088, Memory corruption in mvt_agg_transfn (Victor Collod)
-   - #5137, resetting interrupt flags before query execution (Sergei Shoulbakov)
-   - #5148, ST_Clip is more robust to alignment of raster and clip geometry (Sergei Shoulbakov)
-   - #4932, Bug with geography ST_Intersects / ST_Distance (Paul Ramsey)
-   - #5089, ST_Reverse also reverses components of CompoundCurve (Paul Ramsey)
 PostGIS 3.3.0alpha1
 2022/05/21
diff --git a/README.postgis b/README.postgis
index 69aff4158..95f4a6ba3 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.3.0rc2
-:Date: 2022-08-21
+:Version: 3.3.0
+:Date: 2022-08-26
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
@@ -258,6 +258,12 @@ PostGIS support must be enabled for each database that requires its usage.
 Enabling spatial functionality requires a PostgreSQL super-user.
     CREATE EXTENSION postgis;
+    CREATE EXTENSION postgis_raster;
+    CREATE EXTENSION postgis_sfcgal;
+    CREATE EXTENSION postgis_topology;
+    CREATE EXTENSION address_standardizer;
+    CREATE EXTENSION fuzzystrmatch; -- needed for postgis_tiger_geocoder
+    CREATE EXTENSION postgis_tiger_geocoder;
 UPGRADING EXISTING SPATIAL DATABASES
@@ -265,7 +271,9 @@ UPGRADING EXISTING SPATIAL DATABASES
 Upgrade PostGIS using the "ALTER EXTENSION" facility.
-  ALTER EXTENSION postgis UPDATE TO '2.2.0';
+  ALTER EXTENSION postgis UPDATE;
+  SELECT postgis_extensions_upgrade();
 USAGE
diff --git a/Version.config b/Version.config
index b7f7afe6e..0be9d9785 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 336b21087..097f3a5d0 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -155,7 +155,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   --with-gui --with-gettext=no \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
   --without-interrupt-tests \
-  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
+  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
   #exit
 else
 CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
@@ -169,7 +169,7 @@ LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYP
   --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
 fi;
 make clean
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 886ccf1a5..7c18bbca1 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -253,6 +253,7 @@ export UPGRADEABLE_VERSIONS=$value
 export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
 for EXTNAME in postgis postgis_raster postgis_topology postgis_sfcgal postgis_tiger_geocoder address_standardizer; do
 	cp extensions/$EXTNAME/sql/$EXTNAME--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
+	cp extensions/$EXTNAME/sql/*unpackaged*.sql ${RELDIR}/${RELVERDIR}/share/extension
 	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
 	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
 	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--${POSTGIS_MICRO_VER}next--${POSTGIS_MICRO_VER}.sql
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index b75f02f46..fc250ef7b 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -161,7 +161,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   #exit
 else
@@ -174,7 +174,7 @@ LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYP
 fi;
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 8e0ac27a3..250109adc 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,86 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+        <sect1>
+            <title>PostGIS 3.3.0</title>
+            <para>2022/08/26</para>
+            <para>This version requires PostgreSQL 11 or higher, GEOS 3.6 or higher, and Proj 5.2+.
+            Additional features are enabled if you are running GEOS 3.9+
+            ST_MakeValid enhancements with 3.10+, numerouse additional enhancements with GEOS 3.11+.
+            Requires SFCGAL 1.4.1+ for ST_AlphaShape and ST_OptimalAlphaShape.</para>
+            <para>NOTE: GEOS 3.11.0 details at <ulink url="https://libgeos.org/posts/2022-07-01-geos-3-11-0-released/">GEOS 3.11.0 release notes</ulink></para>
+            <para>The new configure --enable-lto flag improves speed of math computations.  This new feature is disabled by default
+            because on some platforms, causes compilation errors (BSD and MingW64 issues have been raised)</para>
+            <simplesect>
+                <title>New features</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5116">5116</ulink>, Topology export/import scripts (Sandro Santilli)</para>
+                <para>ST_Letters creates geometries that look like letters (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5037">5037</ulink>, postgis_sfcgal: ST_3DConvexHull (Loïc Bartoletti)</para>
+                <para>postgis_sfcgal: sfcgal_full_version - reports BOOST and CGAL version
+                    (Loïc Bartoletti)</para>
+                <para><ulink url="https://github.com/postgis/postgis/pull/659">GH 659</ulink>, MARC21/XML, ST_GeomFromMARC21, ST_AsMARC21 (Jim Jones)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5132">5132</ulink>, <ulink url="https://github.com/postgis/postgis/pull/683">GH 683</ulink>, sfcgal: ST_3DUnion aggregate function (Sergei Shoulbakov)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5143">5143</ulink>, SFCGAL ST_AlphaShape and ST_OptimalAlphaShape
+                            Requires SFCGAL 1.4.1+ (Loïc Bartoletti)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5162">5162</ulink>, ST_TriangulatePolygon with GEOS 3.11+ (Paul Ramsey, Martin Davis)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5162">5162</ulink>, ST_SimplifyPolygonHull with GEOS 3.11+ (Paul Ramsey, Martin Davis)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5183">5183</ulink>, topology.RemoveUnusedPrimitives (Sandro Santilli)</para>
+            </simplesect>
+            <simplesect>
+                <title>Breaking Changes</title>
+                <para>Drop support for PostgreSQL 9.6 and 10 (Regina Obe)</para>
+                <para>Change output for WKT MULTIPOINT. All points now
+                    wrapped in parens. (Even Roualt)</para>
+                <para><ulink url="https://github.com/postgis/postgis/pull/674">GH 674</ulink>, geometry validation and fixing is disabled
+                but might produce invalid polygons. (Aliaksandr Kalenik)</para>
+            </simplesect>
+            <simplesect>
+                <title>Enhancements</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/2861">2861</ulink>, Add index on topology.node(containing_face) speeding up
+                    splitting and merging of faces (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/2083">2083</ulink>, Speed up ST_RemEdge topology functions adding index on
+                    relation(element_id) and edge_data(abs_next*) (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5118">5118</ulink>, Allow dropping topologies with missing topogeometry sequences
+                    (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5111">5111</ulink>, faster topology face MBR computation (Sandro Santilli)</para>
+                <para>postgis_extensions_upgrade() support for upgrades from any PostGIS
+                    version, including yet to be released ones (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5040">5040</ulink>, add postgis_sfcgal_full_version (Loïc Bartoletti)</para>
+                <para><ulink url="https://github.com/postgis/postgis/pull/655">GH 655</ulink>, GiST: balance the tree splits better in recursive calls (Darafei Praliaskouski)</para>
+                <para><ulink url="https://github.com/postgis/postgis/pull/657">GH 657</ulink>, GiST: do not call no-op decompress function (Aliaksandr Kalenik)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/4939">4939</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/5161">5161</ulink>, ST_LineMerge now has option to keep the directions of input linestrings,
+                    useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)</para>
+                <para>ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)</para>
+                <para>ST_ConcaveHull GEOS 3.11+ polygon-respecting native implementation (Paul Ramsey, Martin Davis)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/4574">4574</ulink>, <ulink url="https://github.com/postgis/postgis/pull/678">GH 678</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/5121">5121</ulink> Enable Link-Time Optimizations using --enable-lto (Sergei Shoulbakov)</para>
+                <para><ulink url="https://github.com/postgis/postgis/pull/676">GH 676</ulink>, faster ST_Clip (Aliaksandr Kalenik)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5135">5135</ulink>, Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5158">5158</ulink>, pgtopo_import / pgtopo_export manpages (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5170">5170</ulink>, add a optional max_rows_per_copy to -Y option to raster2pgsql to
+                    Default to 50 when not specified (Regina Obe)</para>
+                <para><ulink url="https://github.com/postgis/postgis/pull/698">GH 698</ulink>, support parallel aggregate for ST_Union (Sergei Shoulbakov)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5024">5024</ulink>, Update spatial_ref_sys as part of ALTER EXTENSION update postgis (Paul Ramsey)</para>
+            </simplesect>
+            <simplesect>
+                <title>Bug Fixes</title>
+                <para>These are fixes issues in prior minors not backported</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/4912">4912</ulink>, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5088">5088</ulink>, Memory corruption in mvt_agg_transfn (Victor Collod)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5137">5137</ulink>, resetting interrupt flags before query execution (Sergei Shoulbakov)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5148">5148</ulink>, ST_Clip is more robust to alignment of raster and clip geometry (Sergei Shoulbakov)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/4932">4932</ulink>, Bug with geography ST_Intersects / ST_Distance (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5089">5089</ulink>, ST_Reverse also reverses components of CompoundCurve (Paul Ramsey)</para>
+            </simplesect>
+    </sect1>
     <sect1>
         <title>PostGIS 3.3.0rc2</title>
         <para>2022/08/22</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index d3c3caaca..b28957b18 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -77,9 +77,4 @@ UPGRADEABLE_VERSIONS = \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
-	3.2.3 \
-	3.3.0alpha1 \
-	3.3.0beta1 \
-	3.3.0beta2 \
-	3.3.0rc1 \
-	3.3.0rc2
+	3.2.3
commit 1550fcc70ee5d9183a5f12a54a87f11006faa7c6
Date:   Fri Aug 26 16:10:12 2022 -0400
    Add note that geos 3.10 is required for newer make valid
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index 66862f459..6c46dc8b8 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -370,7 +370,7 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
     <para>Enhanced: 2.0.1, speed improvements</para>
     <para>Enhanced: 2.1.0, added support for GEOMETRYCOLLECTION and MULTIPOINT.</para>
     <para>Enhanced: 3.1.0, added removal of Coordinates with NaN values.</para>
-    <para>Enhanced: 3.2.0, added algorithm options, 'linework' and 'structure'.</para>
+    <para>Enhanced: 3.2.0, added algorithm options, 'linework' and 'structure' which requires GEOS >= 3.10.0. </para>
     <para>&Z_support;</para>
commit 97892fae085de30dad5ba4d6a6051516262962be
Date:   Fri Aug 26 16:07:08 2022 -0400
    Backport doc changes
diff --git a/doc/po/de/using_postgis_query.xml.po b/doc/po/de/using_postgis_query.xml.po
index b3b5cb26f..3531820c5 100644
--- a/doc/po/de/using_postgis_query.xml.po
+++ b/doc/po/de/using_postgis_query.xml.po
@@ -6,8 +6,8 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-05-03 02:58+0000\n"
-"PO-Revision-Date: 2022-01-15 01:45+0000\n"
-"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"PO-Revision-Date: 2022-08-23 23:30+0000\n"
+"Last-Translator: Juergen E. Fischer <jef at norbit.de>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "using_postgis_queryxml/de/>\n"
 "Language: de\n"
@@ -15,7 +15,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=n != 1;\n"
-"X-Generator: Weblate 4.10.1\n"
+"X-Generator: Weblate 4.13.1\n"
 #. Tag: title
 #: using_postgis_query.xml:3
@@ -33,12 +33,18 @@ msgid ""
 "functions are available, how to use them in queries, and ensuring that "
 "appropriate indexes are in place to provide good performance."
 msgstr ""
+"Der Sinn von räumlichen Datenbanken liegt darin Abfragen in der Datenbank "
+"ausführen zu können, die normalerweise Desktop-GIS-Funktionionalität "
+"verlangen würden. Um PostGIS effektiv verwenden zu können muss man die "
+"verfügbaren räumlichen Funktionen kennen, wissen wie sie in Abfragen "
+"verwendet werden und sicherstellen, dass für gute Performanz  die passenden "
+"Indizes vorhanden sind."
 #. Tag: title
 #: using_postgis_query.xml:14
 #, no-c-format
 msgid "Determining Spatial Relationships"
-msgstr ""
+msgstr "Räumliche Beziehungen feststellen"
 #. Tag: para
 #: using_postgis_query.xml:16
@@ -47,6 +53,8 @@ msgid ""
 "Spatial relationships indicate how two geometries interact with one another. "
 "They are a fundamental capability for querying geometry."
 msgstr ""
+"Räumliche Beziehungen geben an wie zwei Geometrien miteinander interagieren. "
+"Sie sind die fundamentale Fähigkeit zum Abfragen von Geometrie."
 #. Tag: title
 #: using_postgis_query.xml:21
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index ef1c1bfff..9cf04149a 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -916,9 +916,26 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
 		<refsection>
 			<title>Description</title>
-			<para>Creates a rectangular Polygon in <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> (SRID:3857) using the <ulink url="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</ulink>. By default, the bounds are the in EPSG:3857 using the standard range of the Web Mercator system (-20037508.342789, 20037508.342789). The optional bounds parameter can be used to generate envelopes for any tiling scheme: provide a geometry that has the SRID and extent of the initial "zoom level zero" square within which the tile system is to be inscribed.</para>
-			<para>The optional margin parameter can be used to grow a tile by the given percentage, e.g. margin=0.125 grows the tile by 12.5%, which is equivalent to buffer=512 when extent is 4096, as used in <xref linkend="ST_AsMVTGeom" />. This is useful to create a tile buffer -- to include data lying outside of the tile's visible area, but whose existence affects current tile's rendering. For example, a city name (a geopoint) could be near an edge of a tile, but the text would need to render on two tiles, even though the geopoint is located in the visible area of just one tile. Using an expanded tile in a search would include the city geopoint for both tiles. Use negative value to shrink the tile instead. Values less than -0.5 are prohibited because that would eliminate the tile completely. Do not use margin with ST_AsMVTGeom(). See example in <xref linkend="ST_AsMVT" />.</para>
+			<para>Creates a rectangular Polygon
+            giving the extent of a tile in the <ulink url="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</ulink>.
+            The tile is specifed by the zoom level Z and the XY index of the tile in the grid at that level.
+            Can be used to define the tile bounds required by <xref linkend="ST_AsMVTGeom" /> to convert geometry
+            into the MVT tile coordinate space.
+            </para>
+            <para>By default, the tile envelope is in the <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> coordinate system (SRID:3857)
+            using the standard range of the Web Mercator system (-20037508.342789, 20037508.342789).
+            This is the most common coordinate system used for MVT tiles.
+            The optional <varname>bounds</varname> parameter can be used to generate tiles in any coordinate system.
+            It is a geometry that has the SRID and extent of the "Zoom Level zero" square within which the XYZ tile system is inscribed.</para>
+			<para>The optional <varname>margin</varname> parameter can be used to expand a tile by the given percentage.
+            E.g. <varname>margin=0.125</varname> expands the tile by 12.5%, which is equivalent to buffer=512 when the tile extent size is 4096, as used in <xref linkend="ST_AsMVTGeom" />.
+            This is useful to create a tile buffer to include data lying outside of the tile's visible area, but whose existence affects the tile rendering.
+            For example, a city name (a point) could be near an edge of a tile, so its label should be rendered on two tiles, even though the point is located in the visible area of just one tile.
+            Using expanded tiles in a query will include the city point in both tiles.
+            Use a negative value to shrink the tile instead. Values less than -0.5 are prohibited because that would eliminate the tile completely.
+            Do not specify a margin when using with <varname>ST_AsMVTGeom</varname>.
+            See the example for <xref linkend="ST_AsMVT" />.</para>
 			<para>Enhanced: 3.1.0 Added margin parameter.</para>
 			<para>Availability: 3.0.0</para>
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index e07bc22c8..29b95d3d7 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1159,7 +1159,7 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refnamediv>
 		<refname>ST_AsMVTGeom</refname>
-		<refpurpose>Transform a geometry into the coordinate space of a <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink>.</refpurpose>
+		<refpurpose>Transforms a geometry into the coordinate space of a MVT tile.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
 		<funcsynopsis>
@@ -1177,15 +1177,27 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refsection>
-		<para>Transform a geometry into the coordinate space of a <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink> of a set of rows corresponding to a Layer.
-		Makes best effort to keep and even correct validity and might collapse geometry into a lower dimension in the process.
+		<para>Transforms a geometry into the coordinate space of a MVT (<ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink>) tile,
+        clipping it to the tile bounds if required.
+        The geometry must be in the coordinate system of the target map (using <xref linkend="ST_Transform" /> if needed).
+        Commonly this is <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> (SRID:3857).
+        </para>
+		<para>The function attempts to preserve geometry validity, and corrects it if needed.
+        This may cause the result geometry to collapse to a lower dimension.
 		</para>
-		<para><varname>geom</varname> is the geometry to transform.</para>
-		<para><varname>bounds</varname> is the geometric bounds of the tile contents without buffer.</para>
-		<para><varname>extent</varname> is the tile extent in tile coordinate space as defined by the <ulink url="https://www.mapbox.com/vector-tiles/specification/">specification</ulink>. If NULL it will default to 4096.</para>
-		<para><varname>buffer</varname> is the buffer distance in tile coordinate space to optionally clip geometries. If NULL it will default to 256.</para>
-		<para><varname>clip_geom</varname> is a boolean to control if geometries should be clipped or encoded as is. If NULL it will default to true.</para>
+        <para>The rectangular bounds of the tile in the target map coordinate space must be provided,
+        so the geometry can be transformed, and clipped if required.
+        The bounds can be generated using <xref linkend="ST_TileEnvelope" />.
+        </para>
+        <para>
+        This function is used to convert geometry into the tile coordinate space required by <xref linkend="ST_AsMVT" />.
+        </para>
+		<para><varname>geom</varname> is the geometry to transform, in the coordinate system of the target map.</para>
+		<para><varname>bounds</varname> is the rectangular bounds of the tile in map coordinate space, with no buffer.</para>
+		<para><varname>extent</varname> is the tile extent size in tile coordinate space as defined by the <ulink url="https://www.mapbox.com/vector-tiles/specification/">MVT specification</ulink>. Defaults to 4096.</para>
+		<para><varname>buffer</varname> is the buffer size in tile coordinate space for geometry clippig. Defaults to 256.</para>
+		<para><varname>clip_geom</varname> is a boolean to control if geometries are clipped or encoded as-is. Defaults to true.</para>
 		<para>Availability: 2.4.0</para>
@@ -1196,16 +1208,27 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refsection>
 		<title>Examples</title>
-		<programlisting><![CDATA[SELECT ST_AsText(ST_AsMVTGeom(
+		<programlisting>
+SELECT ST_AsText(ST_AsMVTGeom(
 	ST_GeomFromText('POLYGON ((0 0, 10 0, 10 5, 0 -5, 0 0))'),
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)),
 	4096, 0, false));
                               st_astext
  MULTIPOLYGON(((5 4096,10 4091,10 4096,5 4096)),((5 4096,0 4101,0 4096,5 4096)))
 		</programlisting>
+    <para>Canonical example for a Web Mercator tile using a computed tile bounds to query and clip geometry.
+    </para>
+		<programlisting>
+<![CDATA[SELECT ST_AsMVTGeom(
+            ST_Transform( geom, 3857 ),
+            ST_TileEnvelope(12, 513, 412), extent => 4096, buffer => 64) AS geom
+  FROM data
+  WHERE geom && ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096))
+</programlisting>
 	  </refsection>
     <refsection>
@@ -1222,7 +1245,7 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 	  <refnamediv>
 		<refname>ST_AsMVT</refname>
-		<refpurpose>Aggregate function returning a Mapbox Vector Tile representation of a set of rows.</refpurpose>
+		<refpurpose>Aggregate function returning a MVT representation of a set of rows.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
 		<funcsynopsis>
@@ -1264,8 +1287,8 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
 		<para>An aggregate function which returns a binary <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink>
 		representation of a set of rows corresponding to a tile layer.
-		The rows should contain a geometry column which will be encoded as a feature geometry.
-		The geometry should be in tile coordinate space
+		The rows must contain a geometry column which will be encoded as a feature geometry.
+		The geometry must be in tile coordinate space
 		and valid as per the <ulink url="https://www.mapbox.com/vector-tiles/specification/">MVT specification</ulink>.
 		<xref linkend="ST_AsMVTGeom" /> can be used to transform geometry into tile coordinate space.
 		Other row columns are encoded as feature attributes.
Summary of changes:
 NEWS                                 | 150 +++++++++++++++++------------------
 README.postgis                       |  14 +++-
 Version.config                       |   2 +-
 ci/winnie/build_postgis.sh           |   4 +-
 ci/winnie/package_postgis.sh         |   1 +
 ci/winnie/regress_postgis.sh         |   4 +-
 doc/po/de/using_postgis_query.xml.po |  16 +++-
 doc/reference_constructor.xml        |  23 +++++-
 doc/reference_output.xml             |  53 +++++++++----
 doc/reference_validation.xml         |   2 +-
 doc/release_notes.xml                |  80 +++++++++++++++++++
 extensions/upgradeable_versions.mk   |   7 +-
 12 files changed, 244 insertions(+), 112 deletions(-)
hooks/post-receive
