[postgis-tickets] [SCM] postgis.net branch website updated. 6f3c7965035d43695a0fdf3a0433a8c2c7f340c5
Sat Aug 27 12:14:21 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  6f3c7965035d43695a0fdf3a0433a8c2c7f340c5 (commit)
      from  dfb50b493cb224312536ea35b0729ffb3a3ff595 (commit)
revisions in full, below.
commit 6f3c7965035d43695a0fdf3a0433a8c2c7f340c5
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Aug 27 15:14:16 2022 -0400
    PostGIS 3.3.0 release
diff --git a/config/_default/params.toml b/config/_default/params.toml
index c691a00..46b75f2 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -125,7 +125,7 @@ matomoDomain = "matomo.example.com" # Set to Matomo domain
 matomoSiteID = "1" # Default is set to 1, change this to the siteid being tracked
 [postgis]
-version = "3.2.2"
+version = "3.3.0"
 release_docs =  "https://download.osgeo.org/postgis/docs"
 release_source = "https://download.osgeo.org/postgis/source"
 release_notes = "https://git.osgeo.org/gitea/postgis/postgis/raw/tag"
@@ -141,9 +141,8 @@ dev_download = "/stuff"
     is_dev = true
   [postgis.releases.33]
     minor = "3.3"
-    dev = "3.3.0dev"
-    tag = "3.3.0rc2"
-    is_dev = true
+    dev = "3.3.1dev"
+    tag = "3.3.0"
   [postgis.releases.32]
     minor = "3.2"
     dev = "3.2.4dev"
diff --git a/content/post/2022/08-27_postgis-3.3.0.md b/content/post/2022/08-27_postgis-3.3.0.md
new file mode 100644
index 0000000..188c81e
--- /dev/null
+++ b/content/post/2022/08-27_postgis-3.3.0.md
@@ -0,0 +1,67 @@
+title: PostGIS 3.3.0 Released
+layout: post
+category: news
+tags: [release,3.3]
+author: Regina Obe
+date: "2022-08-27"
+thumbnail:
+The PostGIS Team is pleased to release PostGIS 3.3.0.
+<!--more-->
+This release would not be possible without the various developers listed in the credits as well as the companies that provided funding and developer time.
+Companies that contributed significantly to this release are:
+* [Crunchy Data](https://www.crunchydata.com/) Geometry processing functions and improvements to [GEOS](https://libgeos.org)
+* [Kontur](https://www.kontur.io/) Speed improvements to raster, MVT, GiST indexing, better usability of geometry processing.
+* [NetLab](https://strk.kbt.io/services.html) Continuous improvement of PostGIS topology, PostGIS upgrade plumbing,  PostGIS test plumbing, and CI bot management
+* [NIBIO](https://nibio.no) Developer funding for topology improvements
+* [Oslandia](https://oslandia.com) Developer funding for SFCGAL improvements
+* [Paragon Corporation](https://www.paragoncorporation.com) -- General CI bot management, release management, alignment of PostGIS with PostgreSQL versions.
+Best served with [PostgreSQL 15](https://www.postgresql.org/docs/15/release.html). This version of PostGIS can utilize the faster GiST building support API introduced in PostgreSQL 15.
+ If compiled with recently released [GEOS 3.11.0](https://lists.osgeo.org/pipermail/geos-devel/2022-July/010728.html) you can take advantage of new functions added and improvements to some existing functions.  This release also includes many additional functions and improvements for `postgis`, `postgis_raster` , `postgis_sfcgal`, and `postgis_topology` extensions.
+**3.3.0**
+This release supports PostgreSQL 9.6-15, GEOS 3.6 and higher, and proj 5.2 and higher.
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.3.0.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.3.0/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.3.0.pdf) [de]({{< loc "postgis.release_docs">}}/postgis-3.3.0-de.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.3.0.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-3.3/) [de]({{< loc "site.root">}}docs/manual-3.3/postgis-de.html) [ja]({{< loc "site.root">}}docs/manual-3.3/postgis-ja.html) [ko_KR]({{< loc "site.root">}}docs/manual-3.3/postgis-ko_KR.html)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.3.0.epub)
+Details of this release can be found in NEWS file:
+[https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.3.0/NEWS](https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.3.0/NEWS)
+and is also included in the source tar ball.
+If you come across any issues, feel free to report via our
+[ticket tracker](https://trac.osgeo.org/postgis)  or mailing list with details as described in [SUPPORT](https://postgis.net/support/)
+View all [closed tickets for 3.3.0][1].
+After installing the binaries or after running pg_upgrade:
+For upgrading from PostGIS 3.0, do the following which will upgrade all your postgis extensions.
+```postgres
+SELECT postgis_extensions_upgrade();
+For PostGIS 2.5 and below do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+[1]: https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+3.3.0&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
Summary of changes:
 config/_default/params.toml              |  7 ++--
 content/post/2022/08-27_postgis-3.3.0.md | 67 ++++++++++++++++++++++++++++++++
 2 files changed, 70 insertions(+), 4 deletions(-)
 create mode 100644 content/post/2022/08-27_postgis-3.3.0.md
hooks/post-receive
postgis.net
