[postgis-tickets] [PostGIS] #5227: typo in error message line_locate_point: 2st arg isn't a point
PostGIS trac at osgeo.org
Mon Aug 29 21:42:08 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  low      |  Milestone:  PostGIS 3.2.4
Component:  postgis  |    Version:  3.2.x
 Keywords:           |
 When I do this:
 SELECT ST_LineLocatePoint('LINESTRING(1 1, 2 2)'::geometry, 'LINESTRING(2
 2, 3 3)'::geometry);
 I get error:
 ERROR:  line_locate_point: 2st arg isn't a point
 Note if the first isn't a line, you get this which is okay
 ERROR:  line_locate_point: 1st arg isn't a line
 SQL state: XX000
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5227>
