[postgis-tickets] [PostGIS] #5294: Postgis st_transform error: SQL Error [XX000]: ERROR: could not form projection (LWPROJ) from 'srid=7801' to 'srid=4326'
PostGIS trac at osgeo.org
Fri Dec 2 10:03:30 PST 2022
  Reporter:  iknikolov  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.2.4
 Component:  postgis    |    Version:  3.3.x
Resolution:             |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 3.3.3 => PostGIS 3.2.4
Comment:
 You are several micro versions behind the latest stable 3.2.  I'd suggest
 upgrading just to rule out any issues already fixed.
 I'm running below so a bit newer than your setup.
 POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.10.2-CAPI-1.16.0"
 SFCGAL="SFCGAL 1.4.1, CGAL 5.3.1, BOOST 1.74.0" PROJ="8.2.1" GDAL="GDAL
 3.4.1, released 2021/12/27" LIBXML="2.9.13" LIBJSON="0.15"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"  TOPOLOGY RASTER PostgreSQL
 15.1 (Ubuntu 15.1-1.pgdg22.04+1) on aarch64-unknown-linux-gnu, compiled by
 gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, 64-bit
 What does this output in the database that is not working and in your
 others?
 in psql
 \x
 SELECT *
 FROM spatial_ref_sys where srid = 7801;
 mine outputs:
 id      | 7801
 auth_name | EPSG
 auth_srid | 7801
 srtext    | PROJCS["BGS2005 /
 CCS2005",GEOGCS["BGS2005",DATUM["Bulgaria_Geodetic_System_2005",SPHEROID["GRS
 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG
 ","1167"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","7798"]],PROJECTION["Lambert_Conformal_Coni
 c_2SP"],PARAMETER["standard_parallel_1",42],PARAMETER["standard_parallel_2",43.33333333333334],PARAMETER["latitude_of_origin",42.66787568333333],PARAMETER["central_meridian",25.
 5],PARAMETER["false_easting",500000],PARAMETER["false_northing",4725824.3591],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","7801"]]
 proj4text | +proj=lcc +lat_1=42 +lat_2=43.33333333333334
 +lat_0=42.66787568333333 +lon_0=25.5 +x_0=500000 +y_0=4725824.3591
 +ellps=GRS80 +units=m +no_defs
 also can you check what this outputs, in particular the one erroring does
 it fail on this?
 SELECT ST_AsText(ST_Transform(ST_Point(500000, 4725824, 7801), 4326));
 mine outputs: POINT(25.5 42.667872450492496)
 The issue sounds like possibly missing proj grid files so something off
 with your PROJ installation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5294#comment:1>
