[postgis-tickets] [PostGIS] #5297: woodie and dronie not picking up docbook check issues
PostGIS trac at osgeo.org
Sat Dec 3 16:19:02 PST 2022
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  critical   |  Milestone:  PostGIS 3.3.3
Component:  buildbots  |    Version:  master
 Keywords:             |
 I don't know if this is an issue with the parallel build.  That's the only
 real difference I see between dronie/woodie setup and the other cis.
 The other cis were able to pick up this docbook check error:
 https://github.com/postgis/postgis/actions/runs/3610840750/jobs/6084879392
 But dronie and woodie showed green lights.
 https://woodie.osgeo.org/postgis/postgis/build/16/10
 except for failure in pg14 which looks unrelated
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5297>
