[postgis-tickets] [PostGIS] #5281: Start preparing for PostgreSQL move to meson
PostGIS trac at osgeo.org
Sat Dec 3 17:05:07 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS Fund Me
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 FWIW I'm having trouble building PostgreSQL with meson under mingw64,
 gives some cryptic load error.  I noticed the wiki doesn't even talk about
 using mingw, so maybe they assume all windows users are using VS yuck or
 it's the same instruction as Linux, which essentially it is.
 Anyway once I have my meson build issues sorted out, I'll confirm a meson
 build of PostgreSQL can work with our PostGIS setup.  If it does, what
 kind of changes we'd need to move to the meson direction.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5281#comment:1>
