[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-386-g68f392dc0
Wed Dec 7 05:02:30 PST 2022
the project "PostGIS".
       via  68f392dc0387f4f2e97b52213f3e1afa2c5ee6e0 (commit)
      from  32d9b5f117140c239677b695f8bd79aeef8c19b5 (commit)
revisions in full, below.
commit 68f392dc0387f4f2e97b52213f3e1afa2c5ee6e0
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Dec 7 11:47:39 2022 +0100
    Ensure CopyTopology does not violate layer triggers
    Makes sure hierarchical TopoGeometry definitions are always
    loaded AFTER the primitives defining them.
    References #5298 in master branch (3.4.0dev)
    Includes regression test
diff --git a/topology/sql/manage/CopyTopology.sql.in b/topology/sql/manage/CopyTopology.sql.in
index 6f938836d..580d35fd3 100644
--- a/topology/sql/manage/CopyTopology.sql.in
+++ b/topology/sql/manage/CopyTopology.sql.in
@@ -77,7 +77,12 @@ BEGIN
   EXECUTE sql;
   -- Copy layers and their TopoGeometry sequences
-  FOR rec IN SELECT * FROM topology.layer WHERE topology_id = oldtopo_id
+  -- and their TopoGeometry definitions, from primitives
+  -- to hierarchical
+  FOR rec IN
+    SELECT * FROM topology.layer
+    WHERE topology_id = oldtopo_id
+    ORDER BY COALESCE(child_id, 0), layer_id
   LOOP
     INSERT INTO topology.layer (topology_id, layer_id, feature_type,
       level, child_id, schema_name, table_name, feature_column)
@@ -98,17 +103,19 @@ BEGIN
       rec.layer_id,
       atopology
-  END LOOP;
-  -- Copy TopoGeometry definitions
-  EXECUTE format(
-      INSERT INTO %1$I.relation
-      SELECT * FROM %2$I.relation
-    newtopo,
-    atopology
+    -- Copy TopoGeometry definitions
+    EXECUTE format(
+        INSERT INTO %1$I.relation
+        SELECT * FROM %2$I.relation
+        WHERE layer_id = $1
+      newtopo,
+      atopology
+    ) USING rec.layer_id;
+  END LOOP;
   RETURN newtopo_id;
 END
diff --git a/topology/test/regress/copytopology.sql b/topology/test/regress/copytopology.sql
index 6602b0aed..91da3e06f 100644
--- a/topology/test/regress/copytopology.sql
+++ b/topology/test/regress/copytopology.sql
@@ -3,6 +3,7 @@ set client_min_messages to WARNING;
 \i :top_builddir/topology/test/load_topology-4326.sql
 \i ../load_features.sql
 \i ../more_features.sql
+\i ../hierarchy.sql
 SELECT topology.CopyTopology('city_data', 'CITY_data_UP_down') > 0;
@@ -46,12 +47,20 @@ SELECT tableoid::regclass AS sequence_name, last_value,  is_called  from "CITY_d
 SELECT tableoid::regclass AS sequence_name, last_value,  is_called  from "CITY_data_UP_down".topogeo_s_2;
 SELECT tableoid::regclass AS sequence_name, last_value,  is_called  from "CITY_data_UP_down".topogeo_s_3;
-SELECT topology.DropTopology('CITY_data_UP_down');
-SELECT topology.DropTopology('city_data');
-DROP SCHEMA features CASCADE;
+-- See https://trac.osgeo.org/postgis/ticket/5298
+BEGIN;
+UPDATE city_data.relation SEt layer_id = 1 WHERE layer_id = 1;
+SELECT '#5298', topology.CopyTopology('city_data', 'city_data_t5298') > 0;
+ROLLBACK;
 -- See http://trac.osgeo.org/postgis/ticket/2184
 select '#2184.1', topology.createTopology('t3d', 0, 0, true) > 0;
 select '#2184.2', st_addisonode('t3d', NULL, 'POINT(1 2 3)');
 select '#2184.3', topology.copyTopology('t3d', 't3d-bis') > 0;
 select '#2184.4', length(topology.dropTopology('t3d')) > 0, length(topology.dropTopology('t3d-bis')) > 0;
+-- Cleanup
+SELECT topology.DropTopology('CITY_data_UP_down');
+SELECT topology.DropTopology('city_data');
+DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/copytopology_expected b/topology/test/regress/copytopology_expected
index 82a90798b..2d4431f4a 100644
--- a/topology/test/regress/copytopology_expected
+++ b/topology/test/regress/copytopology_expected
@@ -3,11 +3,14 @@ t
 nodes|22
 edges|24
 faces|10
-relations|39
-layers|3
+relations|50
+layers|6
 1|CITY_data_UP_down|LAYER1|
 2|CITY_data_UP_down|LAYER2|
 3|CITY_data_UP_down|LAYER3|
+4|CITY_data_UP_down|LAYER4|
+5|CITY_data_UP_down|LAYER5|
+6|CITY_data_UP_down|LAYER6|
 "CITY_data_UP_down".node_node_id_seq|22|t
 "CITY_data_UP_down".edge_data_edge_id_seq|26|t
 "CITY_data_UP_down".face_face_id_seq|9|t
@@ -15,9 +18,10 @@ layers|3
 "CITY_data_UP_down".topogeo_s_1|9|t
 "CITY_data_UP_down".topogeo_s_2|8|t
 "CITY_data_UP_down".topogeo_s_3|8|t
-Topology 'CITY_data_UP_down' dropped
-Topology 'city_data' dropped
+#5298|t
 #2184.1|t
 #2184.2|1
 #2184.3|t
 #2184.4|t|t
+Topology 'CITY_data_UP_down' dropped
+Topology 'city_data' dropped
Summary of changes:
 topology/sql/manage/CopyTopology.sql.in     | 29 ++++++++++++++++++-----------
 topology/test/regress/copytopology.sql      | 15 ++++++++++++---
 topology/test/regress/copytopology_expected | 12 ++++++++----
 3 files changed, 38 insertions(+), 18 deletions(-)
hooks/post-receive
