[postgis-tickets] [PostGIS] #5301: PostgreSQL 11 3.0.1 upgrade to 3.3.2 fails with ERROR: row is too big: size 8824, maximum size 8160
PostGIS trac at osgeo.org
Sun Dec 11 09:29:09 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.3
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by robe):
 Okay the good news is this issue shouldn't be very common and I don't
 think it's the issue I thought it was.  I think it's the backup config at
 fault.  Now I remember that's the last time I have seen this issue before.
 To try to check if the issue was what I thought it was:
 To try to replicate I did this:
 CREATE EXTENSION postgis; --3.3.2
 TRUNCATE TABLE spatial_ref_sys;
 -- restored the backup of spatial_ref_sys I was given
 SELECT COUNT(*) FROM spatial_ref_sys;
 -- output 471 rows
 SELECT postgis_extensions_upgrade();   -- worked fine
 SELECT count(*) FROM spatial_ref_sys;  -- 8508 rows
 So update of spatial_ref_sys entries I suspect is not the culprit here.
 My next guess is our long
 call to
 SELECT pg_catalog.pg_extension_config_dump('spatial_ref_sys', 'WHERE NOT
 There was a time which I thought it was fixed, when I complained to Tom
 Lane about this that instead of overriting it just kept on appending to
 it.  I forget his comment about it and if he thought it should behave that
 was or is something that needs fixing or if I was supposed to be doing
 something different.
 So next time I have access to that system I'll check what kind of mess
 that entry looks like.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5301#comment:4>
