[postgis-tickets] [PostGIS] #5301: PostgreSQL 11 3.0.1 upgrade to 3.3.2 fails with ERROR: row is too big: size 8824, maximum size 8160
PostGIS trac at osgeo.org
Tue Dec 13 02:40:00 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.3
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by strk):
 As a test you may unpackage the extension (extensions_unpackage.sh) and
 then source postgis_upgrade.sql -- if not else you'd get a line number
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5301#comment:6>
