[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-402-gf29fb6eff
Thu Dec 15 03:58:31 PST 2022
the project "PostGIS".
       via  f29fb6eff3f37ee95cbab8317f929c9b313863b1 (commit)
       via  12467c5eddfbaefa771d332e2e071f5698d2520a (commit)
      from  dd7642ea28694ebc7eddf549ca9dcb856793f974 (commit)
revisions in full, below.
commit f29fb6eff3f37ee95cbab8317f929c9b313863b1
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Dec 15 12:39:47 2022 +0100
    Speedup topology validity check for coincident nodes
    The time required to check for coincident nodes
    in a topology with ~9.5 million nodes on my system
    goes from ~2 minutes down to 8 seconds with this change.
    With this change the planner uses 2 sequence scans and an
    hash join rather than an index scan and nested loop.
    Tested on PostgreSQL 13.
diff --git a/NEWS b/NEWS
index 26bae5461..45262c09d 100644
--- a/NEWS
+++ b/NEWS
@@ -18,6 +18,7 @@ xxxx/xx/xx
   - #635, honour --bindir (and --prefix) configure switch for executables (Sandro Santilli)
   - Honour --mandir (and --prefix) configure switch for man pages install path (Sandro Santilli)
   - Speed up check of topology faces without edges (Sandro Santilli)
+  - Speed up coincident nodes check in topology validation  (Sandro Santilli)
 * Bug Fix *
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index c7d946119..e36e036ee 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -649,7 +649,7 @@ BEGIN
       node a,
       node b
     WHERE a.node_id < b.node_id
-    AND ST_DWithin(a.geom, b.geom, 0) -- NOTE: see #1625 and #1789
+    AND a.geom = b.geom
     AND (
       bbox IS NULL
       OR (
commit 12467c5eddfbaefa771d332e2e071f5698d2520a
Date:   Thu Dec 15 12:48:53 2022 +0100
    Add missing entry about face without edges query speed up
index 87a36be18..26bae5461 100644
--- a/NEWS
+++ b/NEWS
@@ -17,6 +17,7 @@ xxxx/xx/xx
   - #5092, reduce number of upgrade paths installed on system (Sandro Santilli)
+  - Speed up check of topology faces without edges (Sandro Santilli)
 * Bug Fix *
Summary of changes:
 NEWS                                        | 2 ++
 topology/sql/manage/ValidateTopology.sql.in | 2 +-
 2 files changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
