[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-403-g8c0a6c6ec
Mon Dec 19 15:09:01 PST 2022
the project "PostGIS".
       via  8c0a6c6ec2247b1c02f3e35db7aa4f6e99001f94 (commit)
      from  f29fb6eff3f37ee95cbab8317f929c9b313863b1 (commit)
revisions in full, below.
commit 8c0a6c6ec2247b1c02f3e35db7aa4f6e99001f94
Author: Björn Harrtell <bjornharrtell at users.noreply.github.com>
Date:   Fri Dec 16 15:26:28 2022 +0100
    Add additional documented values for feature_type
    Closes https://github.com/postgis/postgis/pull/717
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index beff2f074..4a0978f39 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -319,7 +319,7 @@ ERROR:  value for domain topology.topoelementarray violates check constraint "di
                     Otherwise this layer will contain hierarchical TopoGeometries (composed by TopoGeometries from the child_layer).</para>
                 <para>Once the layer is created (its id is returned by the AddTopoGeometryColumn function) you're ready to construct TopoGeometry objects in it</para>
-                <para>Valid <varname>feature_type</varname>s are: POINT, LINE, POLYGON, COLLECTION</para>
+                <para>Valid <varname>feature_type</varname>s are: POINT, MULTIPOINT, LINE, MULTILINE, POLYGON, MULTIPOLYGON, COLLECTION</para>
                 <!-- use this format if new function -->
                 <para>Availability: 1.1</para>
Summary of changes:
 doc/extras_topology.xml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
