[postgis-tickets] [PostGIS] #5305: codecov not working on GHA
PostGIS trac at osgeo.org
Mon Dec 19 16:03:59 PST 2022
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  high       |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by robe):
 I guess this is controlled by the .github/codecov.yml
 Output looks like:
 ==> git version 2.30.2 found
 ==> curl 7.74.0 (x86_64-pc-linux-gnu) libcurl/7.74.0 OpenSSL/1.1.1n
 zlib/1.2.11 brotli/1.0.9 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0)
 libssh2/1.9.0 nghttp2/1.43.0 librtmp/2.3
 Release-Date: 2020-12-09
 Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps mqtt
 pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
 Features: alt-svc AsynchDNS brotli GSS-API HTTP2 HTTPS-proxy IDN IPv6
 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL TLS-SRP UnixSockets
 x> No CI provider detected.
     Testing inside Docker? http://docs.codecov.io/docs/testing-with-docker
     Testing with Tox? https://docs.codecov.io/docs/python#section-testing-
 with-tox
     current dir:  /src/postgis
     project root: .
     Yaml found at: .github/codecov.yml
 ==> Running gcov in . (disable via -X gcov)
 ./deps/ryu/.libs/d2s.gcda:cannot open data file, assuming not executed
 ./extensions/address_standardizer/address_standardizer.gcda:cannot open
 ./extensions/address_standardizer/lexicon.gcda:cannot open data file,
 ./extensions/address_standardizer/parseaddress-api.gcda:cannot open data
 ./extensions/address_standardizer/tokenize.gcda:cannot open data file,
 ./extensions/address_standardizer/standard.gcda:cannot open data file,
 Not quite sure what is supposed to be building these files.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5305#comment:2>
