[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-418-g4ab073b59
Wed Dec 21 07:57:18 PST 2022
the project "PostGIS".
       via  4ab073b59bd6ec066fee7d4e93674720fee129a3 (commit)
      from  fce2bbce55002b0bde1d59939bbf700ac020b4bf (commit)
revisions in full, below.
commit 4ab073b59bd6ec066fee7d4e93674720fee129a3
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Dec 21 16:56:33 2022 +0100
    New postgis_geos_compiled_version() and exposure in full version
    Only shows compiled version in postgis_full_version() output
    if major/minor do not match.
    Close #5306
diff --git a/NEWS b/NEWS
index 45262c09d..8871a3072 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ xxxx/xx/xx
   - #5229, Drop support for Proj < 6.1 and PG 11 (Regina Obe)
 * New Features *
+  - #5306, expose version of GEOS at compile time (Sandro Santilli)
   - New install-extension-upgrades command in postgis script (Sandro Santilli)
   - #5257, #5261, #5277, Support changes for PostgreSQL 16 (Regina Obe)
   - #5006, GH705, ST_Transform: Support PROJ pipelines (Robert Coup, Koordinates)
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index d94043d53..753873772 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -91,6 +91,7 @@ Datum isring(PG_FUNCTION_ARGS);
 Datum pointonsurface(PG_FUNCTION_ARGS);
 Datum GEOSnoop(PG_FUNCTION_ARGS);
 Datum postgis_geos_version(PG_FUNCTION_ARGS);
+Datum postgis_geos_compiled_version(PG_FUNCTION_ARGS);
 Datum centroid(PG_FUNCTION_ARGS);
 Datum polygonize_garray(PG_FUNCTION_ARGS);
 Datum clusterintersecting_garray(PG_FUNCTION_ARGS);
@@ -122,6 +123,15 @@ Datum postgis_geos_version(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(result);
+PG_FUNCTION_INFO_V1(postgis_geos_compiled_version);
+	const char *ver = lwgeom_geos_compiled_version();
+	text *result = cstring_to_text(ver);
+	PG_RETURN_POINTER(result);
 static char
 is_poly(const GSERIALIZED* g)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 31e7202ae..089863493 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2951,6 +2951,11 @@ CREATE OR REPLACE FUNCTION postgis_geos_version() RETURNS text
 	AS 'MODULE_PATHNAME'
 	LANGUAGE 'c' IMMUTABLE;
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION postgis_geos_compiled_version() RETURNS text
+	AS 'MODULE_PATHNAME'
+	LANGUAGE 'c' IMMUTABLE;
 --- Availability: 3.1.0
 CREATE OR REPLACE FUNCTION postgis_lib_revision() RETURNS text
@@ -3099,6 +3104,7 @@ END
 $$ LANGUAGE plpgsql VOLATILE;
 -- Changed: 3.0.0
+-- Changed: 3.4.0 to include geos compiled version
 CREATE OR REPLACE FUNCTION postgis_full_version() RETURNS text
 AS $$
 DECLARE
@@ -3106,6 +3112,7 @@ DECLARE
 	librev text;
 	projver text;
 	geosver text;
+	geosver_compiled text;
 	sfcgalver text;
 	gdalver text := NULL;
 	libxmlver text;
@@ -3128,6 +3135,7 @@ BEGIN
 	SELECT @extschema at .postgis_lib_version() INTO libver;
 	SELECT @extschema at .postgis_proj_version() INTO projver;
 	SELECT @extschema at .postgis_geos_version() INTO geosver;
+	SELECT @extschema at .postgis_geos_compiled_version() INTO geosver_compiled;
 	SELECT @extschema at .postgis_libjson_version() INTO json_lib_ver;
 	SELECT @extschema at .postgis_libprotobuf_version() INTO protobuf_lib_ver;
 	SELECT @extschema at .postgis_wagyu_version() INTO wagyu_lib_ver;
@@ -3214,6 +3222,10 @@ BEGIN
 	IF  geosver IS NOT NULL THEN
 		fullver = fullver || ' GEOS="' || geosver || '"';
+		IF (string_to_array(geosver, '.'))[1:2] != (string_to_array(geosver_compiled, '.'))[1:2]
+		THEN
+			fullver = format('%s (compiled against GEOS %s)', fullver, geosver_compiled);
+		END IF;
 	END IF;
 	IF  sfcgalver IS NOT NULL THEN
Summary of changes:
 NEWS                   |  1 +
 postgis/lwgeom_geos.c  | 10 ++++++++++
 postgis/postgis.sql.in | 12 ++++++++++++
 3 files changed, 23 insertions(+)
hooks/post-receive
