[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-420-g732064a15
git at osgeo.org
git at osgeo.org
Wed Dec 21 09:38:48 PST 2022
the project "PostGIS".
via 732064a157813018763ce97a1ad68409c420a1e7 (commit)
from b49e4d876e1061375c33ccdd4110114f13142d6c (commit)
revisions in full, below.
commit 732064a157813018763ce97a1ad68409c420a1e7
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Dec 21 18:37:57 2022 +0100
Make TopoGeo_addLinestring performance test more costly
Use more edges for rings, have more nodes of degree 2.
Raises topology build time from ~3 secs to ~30 secs on my system.
diff --git a/topology/test/perf/TopoGeo_addLinestring.sql b/topology/test/perf/TopoGeo_addLinestring.sql
index 59e706a8e..f6066a127 100644
--- a/topology/test/perf/TopoGeo_addLinestring.sql
+++ b/topology/test/perf/TopoGeo_addLinestring.sql
@@ -4,8 +4,9 @@ SELECT topology.CreateTopology('topoperf');
\timing on
-CREATE TABLE topoperf.case_full_coverage_no_holes
-AS SELECT ST_Boundary(geom) g FROM ST_SquareGrid(4, ST_MakeEnvelope(0,0,120,120));
+CREATE TABLE topoperf.case_full_coverage_no_holes AS
+SELECT ST_Subdivide(ST_Segmentize(ST_Boundary(geom), 0.5), 5) g
+FROM ST_SquareGrid(4, ST_MakeEnvelope(0,0,120,120));
SELECT count(*) FROM (
SELECT topology.TopoGeo_addLinestring('topoperf', g)
@@ -13,3 +14,5 @@ SELECT count(*) FROM (
) foo;
\timing off
+SELECT TopologySummary('topoperf');
Summary of changes:
topology/test/perf/TopoGeo_addLinestring.sql | 7 +++++--
1 file changed, 5 insertions(+), 2 deletions(-)
hooks/post-receive
