[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-444-g3b8adbe71
Tue Feb 1 00:48:39 PST 2022
the project "PostGIS".
       via  3b8adbe716e4d00c73d6ef69da9307bdd8a2dd81 (commit)
       via  32ff9e820f5442c909e7ec9d224efad92b943ceb (commit)
      from  1fd865f66f091cd449e5d3cab8b3e4205fb5c189 (commit)
revisions in full, below.
commit 3b8adbe716e4d00c73d6ef69da9307bdd8a2dd81
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Feb 1 09:48:24 2022 +0100
    [dronie] Also print SKIPs in the upgrade summary print
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index cd72d13fb..56104fc76 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -49,4 +49,4 @@ mkfifo check.fifo
 tee check.log < check.fifo &
 ${SRCDIR}/utils/check_all_upgrades.sh -s ${CURRENTVERSION}! > check.fifo
 echo "-- Summary of upgrade tests --"
-egrep '(PASS|FAIL)' check.log
+egrep '(PASS|FAIL|SKIP)' check.log
commit 32ff9e820f5442c909e7ec9d224efad92b943ceb
Date:   Tue Feb 1 01:04:08 2022 +0100
    [dronie] Go back to POSIX shell scripts
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index 91b3885c8..51da3b5aa 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -26,21 +26,21 @@ steps:
     image: *test-image
     pull: never
     commands:
-      - PGVER=9.6 bash ci/dronie/postgis_regress.sh
+      - PGVER=9.6 sh ci/dronie/postgis_regress.sh
     depends_on: [ autogen ]
   - name: build-10
     image: *test-image
     pull: never
     commands:
-      - PGVER=10 bash ci/dronie/postgis_regress.sh
+      - PGVER=10 sh ci/dronie/postgis_regress.sh
   - name: build-11
     image: *test-image
     pull: never
     commands:
-      - PGVER=11 bash ci/dronie/postgis_regress.sh
+      - PGVER=11 sh ci/dronie/postgis_regress.sh
   - name: build-docs
index 195239abb..cd72d13fb 100644
@@ -3,9 +3,6 @@
 # Exit on first error
 set -e
-# Fail the whole pipeline if any pipeline command fails
-set -o pipefail
 service postgresql start $PGVER
 export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
 export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
@@ -48,6 +45,8 @@ RUNTESTFLAGS=-v make installcheck
 CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
-${SRCDIR}/utils/check_all_upgrades.sh -s ${CURRENTVERSION}! | tee check.log
+mkfifo check.fifo
+tee check.log < check.fifo &
+${SRCDIR}/utils/check_all_upgrades.sh -s ${CURRENTVERSION}! > check.fifo
Summary of changes:
 .drone-1.0.yml               | 6 +++---
 ci/dronie/postgis_regress.sh | 9 ++++-----
 2 files changed, 7 insertions(+), 8 deletions(-)
hooks/post-receive
