[postgis-tickets] [PostGIS] #5078: 2.5.6dev--3.3.0dev upgrade fails: cannot change name of input parameter "param_geom"
PostGIS trac at osgeo.org
Tue Feb 1 03:38:40 PST 2022
"param_geom"
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.3.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis VERSION
 '2.5.6dev' SCHEMA public
 Upgrading from postgis 2.5.6dev
 Running before-upgrade-script ../regress/hooks/hook-before-upgrade.sql
 Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
 TO '3.3.0dev'
  failed (Error encountered updating EXTENSION POSTGIS:
 /tmp/pgis_reg/regress_log)
 NOTICE:  schema "public" already exists, skipping
 CREATE SCHEMA
 CREATE EXTENSION
 CREATE SCHEMA
 SET
 CREATE TABLE
 INSERT 0 2
 DO
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 UPDATE 592
 WARNING:  unpackaging raster
 WARNING:  PostGIS Raster functionality has been unpackaged
 HINT:  type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
 After upgrading, if you want to drop raster, run: DROP EXTENSION
 postgis_raster;
 ERROR:  cannot change name of input parameter "param_geom"
 HINT:  Use DROP FUNCTION st_concavehull(geometry,double precision,boolean)
 first.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5078>
