[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-447-gcd088252f
Tue Feb 1 04:29:11 PST 2022
the project "PostGIS".
       via  cd088252f43d41ca36d391f4a54b4de0ef216c89 (commit)
       via  df6f2fc358a51803adbc059f152c0459f6a4dda6 (commit)
       via  1c6ff3a76bf43767f5ddbba042774d29aa91864c (commit)
      from  3b8adbe716e4d00c73d6ef69da9307bdd8a2dd81 (commit)
revisions in full, below.
commit cd088252f43d41ca36d391f4a54b4de0ef216c89
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Feb 1 13:27:41 2022 +0100
    [dronie] wait for tee background to complete before moving on
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 56104fc76..f74054b94 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -48,5 +48,6 @@ CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste
 mkfifo check.fifo
 tee check.log < check.fifo &
 ${SRCDIR}/utils/check_all_upgrades.sh -s ${CURRENTVERSION}! > check.fifo
+wait # for tee process to flush its buffers
 echo "-- Summary of upgrade tests --"
 egrep '(PASS|FAIL|SKIP)' check.log
commit df6f2fc358a51803adbc059f152c0459f6a4dda6
Date:   Tue Feb 1 09:00:16 2022 +0100
    [dronie] Test PG12
    Closes #5077
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index 51da3b5aa..5c45e1810 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -43,6 +43,13 @@ steps:
       - PGVER=11 sh ci/dronie/postgis_regress.sh
     depends_on: [ autogen ]
+  - name: build-12
+    image: *test-image
+    pull: never
+    commands:
+      - PGVER=12 sh ci/dronie/postgis_regress.sh
+    depends_on: [ autogen ]
   - name: build-docs
     image: *test-image
     pull: never
commit 1c6ff3a76bf43767f5ddbba042774d29aa91864c
Date:   Tue Feb 1 09:30:44 2022 +0100
    check_all_ugprades: skip unsupported upgrades
    References #5077
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 9e49c295d..905c7ceb8 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -57,6 +57,9 @@ semver_compare()
 BUILDDIR=$PWD
 EXTDIR=`pg_config --sharedir`/extension/
 CTBDIR=`pg_config --sharedir`/contrib/
+PGVER=`pg_config --version | awk '{print $2}'`
+echo "PostgreSQL version: ${PGVER}"
 cd $EXTDIR
 failures=0
@@ -79,6 +82,34 @@ failed()
   fi
+compatible_upgrade()
+  upgrade_path=$1
+  from=$2
+  to=$3
+  #echo "XXXX compatible_upgrade: upgrade_path=${upgrade_path}"
+  #echo "XXXX compatible_upgrade: from=${from}"
+  #echo "XXXX compatible_upgrade: to=${to}"
+  # only consider versions older than ${to_version_param}
+  cmp=`semver_compare "${from}" "${to}"`
+  if test $cmp -ge 0; then
+    echo "SKIP: upgrade $upgrade_path ($to is not newer than $from)"
+    return 1
+  fi
+  cmp=`semver_compare "${PGVER}" "11"`
+    cmp=`semver_compare "3.0" "${from}"`
+      echo "SKIP: upgrade $UPGRADE_PATH ($from < 3.0 which is required to run in PostgreSQL ${PGVER})"
+      return 1
+    fi
+  fi
+  return 0
 for EXT in ${INSTALLED_EXTENSIONS}; do
   if test "${EXT}" = "postgis"; then
     REGDIR=${BUILDDIR}/regress
@@ -98,12 +129,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
     from_version="$fname"
     UPGRADE_PATH="${from_version}--${to_version_param}"
     UPGRADE_FILE="${EXT}--${from_version}--${to_version}.sql"
-    # only consider versions older than ${to_version}
-    cmp=`semver_compare "${from_version}" "${to_version}"`
-    if test $cmp -ge 0; then
-      echo "SKIP: upgrade $UPGRADE_PATH ($to_version is not newer than $from_version)"
-      continue
-    fi
+    compatible_upgrade ${UPGRADE_PATH} ${from_version} ${to_version} || continue
     if test -e ${UPGRADE_FILE}; then
       if expr $to_version_param : ':auto' >/dev/null; then
         echo "Testing ${EXT} upgrade $UPGRADE_PATH ($to_version)"
@@ -130,12 +156,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
       echo "SKIP: ${EXT} upgrade $UPGRADE_FILE is missing"
       continue
     fi
-    # only consider versions older than ${to_version_param}
-    cmp=`semver_compare "${majmin}" "${to_version}"`
-      echo "SKIP: upgrade $UPGRADE_PATH ($to_version_param is not newer than $majmin)"
-      continue
-    fi
+    compatible_upgrade ${UPGRADE_PATH} ${majmin} ${to_version} || continue
     else
Summary of changes:
 .drone-1.0.yml               |  7 +++++++
 ci/dronie/postgis_regress.sh |  1 +
 utils/check_all_upgrades.sh  | 45 ++++++++++++++++++++++++++++++++------------
 3 files changed, 41 insertions(+), 12 deletions(-)
hooks/post-receive
