[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-455-ga8de642a3
Wed Feb 2 07:10:55 PST 2022
the project "PostGIS".
       via  a8de642a310c58793b03f35aff6e58938a94fb78 (commit)
      from  ffe8971e3e33f8699cab13a4dfb5118e8257f95b (commit)
revisions in full, below.
commit a8de642a310c58793b03f35aff6e58938a94fb78
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 2 16:10:28 2022 +0100
    Do not change ST_ConcaveHull signature
    Fixes #5078
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 4901e3b73..0f86459c4 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6449,9 +6449,10 @@ CREATE OR REPLACE FUNCTION ST_SquareGrid(size float8, bounds geometry, OUT geom
 #if POSTGIS_GEOS_VERSION >= 31100
--- Availability: 3.3.0
-CREATE OR REPLACE FUNCTION ST_ConcaveHull(geom geometry, area_ratio float8, allow_holes boolean DEFAULT false)
+-- Availability: 2.0.0
+-- Changed: 2.5.0
+-- Enhanced: 3.3.0 implements it in C, if GEOS >= 3.10
+CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex float, param_allow_holes boolean DEFAULT false)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_ConcaveHull'
 	LANGUAGE 'c' IMMUTABLE STRICT
@@ -6546,6 +6547,7 @@ LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE _COST_HIGH;
 -- Changed: 2.5.0
 CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex float, param_allow_holes boolean DEFAULT false) RETURNS geometry AS
 	DECLARE
Summary of changes:
 postgis/postgis.sql.in | 8 +++++---
 1 file changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
