[postgis-tickets] [PostGIS] #5079: concaveHull test fails with current GEOS main branch
PostGIS trac at osgeo.org
Wed Feb 2 10:45:39 PST 2022
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Comment (by pramsey):
 You are running a test that is meant to be run only with GEOS < 3.11
 against the main of GEOS. If you check the Makefile you'll see that the
 concave hull tests only run for older GEOS. I don't entirely believe that
 testing the behaviour of our upstream carefully is super healthy, although
 I could add some tests along the lines of "function turns over and doesn't
 crash".
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5079#comment:2>
